2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: obscure EPICS+RTEMS makefile problem
To: "Johnson, Andrew N." <[email protected]>
Cc: EPICS core-talk <[email protected]>
Date: Tue, 17 Apr 2018 22:17:20 -0700
On 04/17/2018 09:31 PM, Johnson, Andrew N. wrote:
> Why wouldn’t you put the workaround in the file CONFIG.Common.RTEMS where you don’t need a conditional test?
Do you mean in Base or external modules?  If Base, then because I wanted
to hear from you first.  If external, I don't think this works with
$(OS_CLASS) granularity.
> I haven’t looked into why you’re only just noticing this now, but there are a few possibilities that I could come up with.
My guess is that it will come down to a mixture of not enough RTEMS/vxworks
builds, with a dose of GNUMake trivia thrown in.
I noticed this when adding a new generated header in pva2pva.  At first
I assumed it was a dep. problem on my end.  However, while a clean
sequential (not -j) build was always successful.  A clean parallel build
would sometimes fail.  When it did fail, a sequential rebuild would also
fail.  Which is when I noticed the missing '-p'.
This is coming from either RTEMS 4.9.6 or 4.10.2.  Both install
'make/host.cfg', and I can't remember the order in which I built them.
Re: obscure EPICS+RTEMS makefile problem Andrew Johnson
obscure EPICS+RTEMS makefile problem Michael Davidsaver
Re: obscure EPICS+RTEMS makefile problem Johnson, Andrew N.
Prev: Re: obscure EPICS+RTEMS makefile problem Johnson, Andrew N.
Next: Re: CA get of zero length array Michael Davidsaver
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Next: Re: obscure EPICS+RTEMS makefile problem Andrew Johnson
ANJ, 18 Apr 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
