I remembered that there is an issue open for this
https://bugs.launchpad.net/epics-base/+bug/1242919
On 04/17/2018 11:40 AM, Michael Davidsaver wrote:
> On 04/17/2018 06:18 AM, Jörn Dreyer wrote:
>> ~ $caget -d 2 HIBEF:XFEL:image1:ArrayData | more
>> Native data type: DBF_FLOAT
>> Request type: DBR_FLOAT
>> Element count: 1000
>> Value: 2.02038e-39 0 ...
> Don't ask me why, but I was annoyed at seeing (again) this garbage element
> in what should be a zero'd array. So I traced it back. The issue is in
> camessage.c in read_reply(). Specifically, that
>> dbr_size_n(X,0) == dbr_size_n(X,1)
> as the underlying dbr_size[] includes the size of meta-data and one value element.
> So dbChannel_get_count() correctly sets item_count to zero. Then read_reply()
> zeros part, but all, of the buffer. In this case data_size includes the first
> value element, which isn't set by dbChannel_get_count(), and not isn't zeroed
> here.
>> ca_uint32_t data_size = dbr_size_n(pevext->msg.m_dataType, item_count);
>> memset((char *) pPayload + data_size, 0, payload_size - data_size);
> This is only in the !autosize case (get or non-dynamic monitor).
> I'm not sure where to fix this, as there would seem to be several possibilities,
> depending on whether or not dbr_size_n() should change.
- CA get of zero length array Michael Davidsaver
Re: obscure EPICS+RTEMS makefile problem Michael Davidsaver
Re: obscure EPICS+RTEMS makefile problem Andrew Johnson
<2018>
2025
2026
<2018>
2025
2026
