Hi Bruno,
I agree that the C++ implementation seemingly uses -1 in the first byte to encode "empty" and -2 to encode "string of size >= 2^8-2". Houston, we have a problem.
(The value you are missing in the third case of the spec is explicitly mentioned there as 2^31-1.)
Cheers, ~Ralph
I was taking a look at how messages are de/serialized by pvData and pvAccess and I think there is an inconsistency between the spec and the implementation regarding how sizes are encoded. The spec says, basically [1]: If size < 2^8-1, encode byte directly If size < 2^31-1, encode -1 as byte and then size as signed 32-bit integer If size < 2^63-1, encode -1 as byte, then a positive 32-bit int (which value? -1?), then size as a signed 64-bit integer. The implementation (C++) does [2]: If size == -1, encode -1 as byte (what is this used for?) If size < 2^8 - 2, encode size directly as byte Else encode -2 as byte, size as signed 32-bit integer
- Re: Size encoding Benjamin Franksen
- Size encoding Bruno Martins
random half finished features Michael Davidsaver
<2018>
2025
2026
<2018>
2025
2026
ANJ, 16 May 2018 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
