Here is the corresponding code from pvDataJava:
(https://github.com/epics-base/pvDataJava/blob/master/src/org/epics/pvdata/misc/SerializeHelper.java#L17)
* Serialize the specified array size into the specified buffer.
* @param s size to encode
* @param buffer the buffer to be serialized into
private final static void writeSize(final int s, ByteBuffer buffer) {
if (s == -1) // null
buffer.put((byte)-1);
else if (s < 254)
buffer.put((byte)s);
else
buffer.put((byte)-2).putInt(s); // (byte)-2 + size
BTW. What I personally find most striking about this is how the
documentation tells us only those things anyone with an IQ above 20 can
guess from the names of class, method, and parameters, while carefully
avoiding to mention things a human reader might find interesting, such as
* where do I find a specification of the encoding?
* what happens if I pass a negative size?
* are there any other exceptional conditions?
Cheers
Ben
On 05/15/2018 03:46 PM, Ralph Lange wrote:
> Hi Bruno,
> I agree that the C++ implementation seemingly uses -1 in the first byte to
> encode "empty" and -2 to encode "string of size >= 2^8-2".
> Houston, we have a problem.
> (The value you are missing in the third case of the spec is explicitly
> mentioned there as 2^31-1.)
> Cheers,
> ~Ralph
> On Tue, May 15, 2018 at 3:13 PM Bruno Martins <[email protected]> wrote:
>> Hi,
>> I was taking a look at how messages are de/serialized by pvData and
>> pvAccess and I think there is an inconsistency between the spec and the
>> implementation regarding how sizes are encoded.
>> The spec says, basically [1]:
>> If size < 2^8-1, encode byte directly
>> If size < 2^31-1, encode -1 as byte and then size as signed 32-bit integer
>> If size < 2^63-1, encode -1 as byte, then a positive 32-bit int (which
>> value? -1?), then size as a signed 64-bit integer.
>> The implementation (C++) does [2]:
>> If size == -1, encode -1 as byte (what is this used for?)
>> If size < 2^8 - 2, encode size directly as byte
>> Else encode -2 as byte, size as signed 32-bit integer
>> [1]
>> http://epics-pvdata.sourceforge.net/pvAccess_Protocol_Specification.html#dataEncoding:sizes
>> [2]
>> https://github.com/epics-base/pvDataCPP/blob/207efca15cf471bbc2990cbd336000e04dcfcd22/src/misc/serializeHelper.cpp#L34
signature.asc
Description: OpenPGP digital signature
- Re: Size encoding Michael Davidsaver
- Size encoding Bruno Martins
- Re: Size encoding Ralph Lange
random half finished features Michael Davidsaver
Build failed in Jenkins: epics-base-3.14 #287 APS Jenkins
<2018>
2025
2026
<2018>
2025
2026
