2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Travis emails?
To: "Johnson, Andrew N." <[email protected]>
Cc: EPICS core-talk <[email protected]>
Date: Sun, 16 Sep 2018 07:20:36 -0700
On 09/15/2018 06:47 PM, Johnson, Andrew N. wrote:
> I haven’t worked out yet why the Travis build of 3.14 was failing. I tried using GnuMake 3.82 on Friday and couldn’t replicate the failure, but I’m pretty sure that it will occur on the other branches as soon as I merge up so I should probably commit the fix to the 3.14 branch first if we can work out what needs changing.
Ubuntu 14.04.5 LTS has Make 3.81 which seems to not understand 'undefine'.
> cat <<EOF >test.make
> FOO:=4
> undefine FOO
> EOF
> make -f test.make
Gives me the same "missing separator" error unless I comment out "undefine FOO".
Re: Travis emails? Torsten Bögershausen
Travis emails? Andrew Johnson
Re: Travis emails? Michael Davidsaver
Re: Travis emails? Johnson, Andrew N.
Prev: Re: Travis emails? Johnson, Andrew N.
Next: Re: Travis emails? Torsten Bögershausen
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
ANJ, 17 Sep 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
