Thanks Michael -
make 3.81 under Mac OS doesn’t understand "undefine“ either.
Needless to say: the following makes it work again:
diff --git a/configure/CONFIG b/configure/CONFIG
index f5ba0b780..722449535 100644
--- a/configure/CONFIG
+++ b/configure/CONFIG
@@ -27,7 +27,6 @@ ifeq ($(origin EPICS_HOST_ARCH), undefined)
$(TOP)/src/tools/EpicsHostArch.pl))
# NB: We use a simply expanded variable here for performance:
export EPICS_HOST_ARCH := $(shell perl $(EHA))
- undefine EHA
endif
-include $(CONFIG)/os/CONFIG_COMPAT
> Am 16.09.2018 um 16:20 schrieb Michael Davidsaver <[email protected]>:
> On 09/15/2018 06:47 PM, Johnson, Andrew N. wrote:
>> I haven’t worked out yet why the Travis build of 3.14 was failing. I tried using GnuMake 3.82 on Friday and couldn’t replicate the failure, but I’m pretty sure that it will occur on the other branches as soon as I merge up so I should probably commit the fix to the 3.14 branch first if we can work out what needs changing.
> Ubuntu 14.04.5 LTS has Make 3.81 which seems to not understand 'undefine'.
>> cat <<EOF >test.make
>> FOO:=4
>> undefine FOO
>> EOF
>> make -f test.make
> Gives me the same "missing separator" error unless I comment out "undefine FOO".
- Travis emails? Andrew Johnson
- Re: Travis emails? Michael Davidsaver
- Re: Travis emails? Johnson, Andrew N.
Build failed in Jenkins: epics-base-3.15-ios #194 APS Jenkins
<2018>
2025
2026
Re: Travis emails? Dirk Zimoch
<2018>
2025
2026
