2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Travis emails?
To: <[email protected]>
Date: Tue, 18 Sep 2018 09:28:06 +0200
The compiler is gcc 3.4.4 from vxWorks 6.3.
On 18.09.2018 09:17, Dirk Zimoch wrote:
I wondered why I have not seen anything in our Jenkins and just found out that the settings were broken and I have not actually built anything for the last few weeks.
After fixing it I got success for 3.14, 3.15, 3.16 and failure for 7.
../../src/factory/FieldCreateFactory.cpp: In member function `size_t epics::pvData::Structure::getFieldIndex(const std::string&) const': ../../src/factory/FieldCreateFactory.cpp:529: warning: converting of negative value `-0x00000000000000001' to `size_t' ../../src/factory/FieldCreateFactory.cpp: In member function `size_t epics::pvData::Union::getFieldIndex(const std::string&) const': ../../src/factory/FieldCreateFactory.cpp:723: warning: converting of negative value `-0x00000000000000001' to `size_t' ../../src/factory/FieldCreateFactory.cpp: In static member function `static void epics::pvData::FieldCreate::Helper::cache(const epics::pvData::FieldCreate*, boost::shared_ptr<T>&) [with FLD = epics::pvData::BoundedString]':
../../src/factory/FieldCreateFactory.cpp:1134:   instantiated from here
../pv/pvIntrospect.h:352: error: `unsigned int epics::pvData::Field::m_hash' is private
../../src/factory/FieldCreateFactory.cpp:58: error: within this context
This error actually popped up several times.
Dirk
On 14.09.2018 23:10, Andrew Johnson wrote:
So why hasn't Travis been sending me emails about the broken epics-base
builds that I've been pushing? It's a shame that the final 3.14.12.8
build failed on Travis, but I'm not going to fix it and re-tag. I
assumed that the absence of emails from it was an indication of no build
problems, but no... (I haven't even checked Appveyor).
I really don't understand how/when Travis (and Appveyor for that matter)
decide when they should email me; can anyone explain where/how I should
change my settings to ensure that it does?
- Andrew
Re: Travis emails? Michael Davidsaver
Travis emails? Andrew Johnson
Re: Travis emails? Dirk Zimoch
Prev: Re: Travis emails? Dirk Zimoch
Next: parallel builds and O.Common Benjamin Franksen
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Next: Re: Travis emails? Michael Davidsaver
ANJ, 19 Sep 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
