2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Travis emails?
To: Dirk Zimoch <[email protected]>
Cc: [email protected]
Date: Wed, 19 Sep 2018 11:06:07 -0700
I've made an attempt to fix this with https://github.com/epics-base/pvDataCPP/commit/a02a60c6580572f1e2945b3ebccb7c1eabfc40f8
On 09/18/2018 12:28 AM, Dirk Zimoch wrote:
> The compiler is gcc 3.4.4 from vxWorks 6.3.
> On 18.09.2018 09:17, Dirk Zimoch wrote:
>> Hi,
>> I wondered why I have not seen anything in our Jenkins and just found out that the settings were broken and I have not actually built anything for the last few weeks.
>> After fixing it I got success for 3.14, 3.15, 3.16 and failure for 7.
>> ../../src/factory/FieldCreateFactory.cpp: In member function `size_t epics::pvData::Structure::getFieldIndex(const std::string&) const':
>> ../../src/factory/FieldCreateFactory.cpp:529: warning: converting of negative value `-0x00000000000000001' to `size_t'
>> ../../src/factory/FieldCreateFactory.cpp: In member function `size_t epics::pvData::Union::getFieldIndex(const std::string&) const':
>> ../../src/factory/FieldCreateFactory.cpp:723: warning: converting of negative value `-0x00000000000000001' to `size_t'
>> ../../src/factory/FieldCreateFactory.cpp: In static member function `static void epics::pvData::FieldCreate::Helper::cache(const epics::pvData::FieldCreate*, boost::shared_ptr<T>&) [with FLD = epics::pvData::BoundedString]':
>> ../../src/factory/FieldCreateFactory.cpp:1134:   instantiated from here
>> ../pv/pvIntrospect.h:352: error: `unsigned int epics::pvData::Field::m_hash' is private
>> ../../src/factory/FieldCreateFactory.cpp:58: error: within this context
>> This error actually popped up several times.
>> Dirk
>> On 14.09.2018 23:10, Andrew Johnson wrote:
>>> So why hasn't Travis been sending me emails about the broken epics-base
>>> builds that I've been pushing? It's a shame that the final 3.14.12.8
>>> build failed on Travis, but I'm not going to fix it and re-tag. I
>>> assumed that the absence of emails from it was an indication of no build
>>> problems, but no... (I haven't even checked Appveyor).
>>> I really don't understand how/when Travis (and Appveyor for that matter)
>>> decide when they should email me; can anyone explain where/how I should
>>> change my settings to ensure that it does?
>>> - Andrew
Re: Travis emails? Dirk Zimoch
Travis emails? Andrew Johnson
Prev: Re: Problem with performstruct test Michael Davidsaver
Next: Re: Problem with performstruct test Johnson, Andrew N.
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Travis emails? Dirk Zimoch
Next: Re: Travis emails? Dirk Zimoch
ANJ, 20 Sep 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
