2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Problem with performstruct test
To: "Johnson, Andrew N." <[email protected]>, "[email protected]" <[email protected]>
Date: Wed, 19 Sep 2018 10:56:45 -0700
On 09/19/2018 08:12 AM, Johnson, Andrew N. wrote:
> Hi Dirk,
> On 09/19/2018 03:13 AM, Dirk Zimoch wrote:
>> On 19.09.2018 10:01, Dirk Zimoch wrote:
>>> Then I recognized that all the other tests in the Makefile have a line
>>> TESTS += ...
>>> but performstruct has not. Is this a bug?
> Nope...
Correct, this is an attempt to quantify the cost of https://github.com/epics-base/pvDataCPP/pull/55
and is frankly of limited usefulness.  If it causes any further problems I'll just remove it.
>> ... There are a few other similar test
> programs spread around the Base tree which are intended for manual
> operation only and should not be added to TESTS.
Other than not having "test" in the executable name, I haven't noticed
any systematic way to distinguish these.  (eg. cvtFastPerform in libCom/test)
Re: Problem with performstruct test Johnson, Andrew N.
Problem with performstruct test Dirk Zimoch
Re: Problem with performstruct test Dirk Zimoch
Prev: Re: Problem with performstruct test Johnson, Andrew N.
Next: Re: Travis emails? Michael Davidsaver
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Next: Re: Problem with performstruct test Johnson, Andrew N.
ANJ, 19 Sep 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
