Hi Dirk,
On 09/19/2018 03:13 AM, Dirk Zimoch wrote:
> On 19.09.2018 10:01, Dirk Zimoch wrote:
>> Then I recognized that all the other tests in the Makefile have a line
>> TESTS += ...
>> but performstruct has not. Is this a bug?
Nope...
> Hmm.... when adding it to TESTS I get
> $make runtests
> performstruct.t ......... skipped: (no reason given)
> What does this mean?
All our test programs have human-readable output, the Test Anything
Protocol (TAP) output was designed for that. If you run this program by
hand you get this output:
> tux% ./performstruct
> # void {anonymous}::buildMiss()
> # 1000 sample 18.938251 +- 3.830785 us
> # void {anonymous}::buildHit()
> # 1000 sample 16.096664 +- 1.622438 us
> Results
> Tests: 0
As you can see, it's doing some performance measurement, not functional
testing. That's why it isn't included in the list of tests that get run
by 'make runtests' and friends. There are a few other similar test
programs spread around the Base tree which are intended for manual
operation only and should not be added to TESTS.
- Andrew
- Re: Problem with performstruct test Michael Davidsaver
- Problem with performstruct test Dirk Zimoch
- Re: Problem with performstruct test Dirk Zimoch
<2018>
2025
2026
<2018>
2025
2026
