Works. Thanks. The newer compilers seem to agree that if A is a friend
then A::B is a fiend as well. The older compiler seems to have a
different opinion on friendship.
On 19.09.2018 20:06, Michael Davidsaver wrote:
I've made an attempt to fix this with https://github.com/epics-base/pvDataCPP/commit/a02a60c6580572f1e2945b3ebccb7c1eabfc40f8
On 09/18/2018 12:28 AM, Dirk Zimoch wrote:
The compiler is gcc 3.4.4 from vxWorks 6.3.
On 18.09.2018 09:17, Dirk Zimoch wrote:
I wondered why I have not seen anything in our Jenkins and just found out that the settings were broken and I have not actually built anything for the last few weeks.
After fixing it I got success for 3.14, 3.15, 3.16 and failure for 7.
../../src/factory/FieldCreateFactory.cpp: In member function `size_t epics::pvData::Structure::getFieldIndex(const std::string&) const':
../../src/factory/FieldCreateFactory.cpp:529: warning: converting of negative value `-0x00000000000000001' to `size_t'
../../src/factory/FieldCreateFactory.cpp: In member function `size_t epics::pvData::Union::getFieldIndex(const std::string&) const':
../../src/factory/FieldCreateFactory.cpp:723: warning: converting of negative value `-0x00000000000000001' to `size_t'
../../src/factory/FieldCreateFactory.cpp: In static member function `static void epics::pvData::FieldCreate::Helper::cache(const epics::pvData::FieldCreate*, boost::shared_ptr<T>&) [with FLD = epics::pvData::BoundedString]':
../../src/factory/FieldCreateFactory.cpp:1134: instantiated from here
../pv/pvIntrospect.h:352: error: `unsigned int epics::pvData::Field::m_hash' is private
../../src/factory/FieldCreateFactory.cpp:58: error: within this context
This error actually popped up several times.
Dirk
On 14.09.2018 23:10, Andrew Johnson wrote:
So why hasn't Travis been sending me emails about the broken epics-base
builds that I've been pushing? It's a shame that the final 3.14.12.8
build failed on Travis, but I'm not going to fix it and re-tag. I
assumed that the absence of emails from it was an indication of no build
problems, but no... (I haven't even checked Appveyor).
I really don't understand how/when Travis (and Appveyor for that matter)
decide when they should email me; can anyone explain where/how I should
change my settings to ensure that it does?
- Andrew
- Travis emails? Andrew Johnson
- Re: Travis emails? Dirk Zimoch
- Re: Travis emails? Michael Davidsaver
Build failed in Jenkins: epics-7.0 » mac #64 APS Jenkins
PSI Jenkins Dirk Zimoch
<2018>
2025
2026
Build failed in Jenkins: epics-base-3.15-ios #194 APS Jenkins
<2018>
2025
2026
ANJ, 20 Sep 2018 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
