2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Problem with performstruct test
To: <[email protected]>
Date: Wed, 19 Sep 2018 10:40:36 +0200
How to propose a merge?
I have pushed a fix to https://code.launchpad.net/~dirk.zimoch/epics-base/+git/epics-base/+ref/fix_performstruct_test, but when trying to create a merge request, I don't know what to put in for "Target branch". I always get the error "The target path must be the path of a reference in the target repository" but no help on what valid values may be.
Also I am not sure if I did everything correct with the sub-module structure. Is "lp:epics-base" the correct target repo or do I have to specify something else when fixing a sub-module?
Dirk
On 19.09.2018 10:13, Dirk Zimoch wrote:
On 19.09.2018 10:01, Dirk Zimoch wrote:
Hello,
In pvData/testApp/pv is a test "performstruct" which uses clock_gettime(). With older glibc versions it is required to link this with "rt". Thus I have added
performstruct_SYS_LIBS_Linux += rt
to pvData/testApp/pv/Makefile.
Then I recognized that all the other tests in the Makefile have a line
TESTS += ...
but performstruct has not. Is this a bug?
Dirk
Hmm.... when adding it to TESTS I get
$make runtests
performstruct.t ......... skipped: (no reason given)
What does this mean?
Re: Problem with performstruct test Ralph Lange
Problem with performstruct test Dirk Zimoch
Re: Problem with performstruct test Dirk Zimoch
Prev: Re: Problem with performstruct test Dirk Zimoch
Next: Re: Problem with performstruct test Ralph Lange
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
ANJ, 19 Sep 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
