Hi Dirk,
The PVA modules (and Git submodules) in the modules directory of Base are not hosted on Launchpad, but have always been on GitHub. (Being hosted in a different repo on a different server is one of the reasons why they are Git submodules in the first place.)
Please issue a regular PR on GitHub.
Cheers, ~Ralph
How to propose a merge?
I have pushed a fix to
https://code.launchpad.net/~dirk.zimoch/epics-base/+git/epics-base/+ref/fix_performstruct_test,
but when trying to create a merge request, I don't know what to put in
for "Target branch". I always get the error "The target path must be the
path of a reference in the target repository" but no help on what valid
values may be.
Also I am not sure if I did everything correct with the sub-module
structure. Is "lp:epics-base" the correct target repo or do I have to
specify something else when fixing a sub-module?
Dirk
On 19.09.2018 10:13, Dirk Zimoch wrote:
> On 19.09.2018 10:01, Dirk Zimoch wrote:
>> Hello,
>> In pvData/testApp/pv is a test "performstruct" which uses
>> clock_gettime(). With older glibc versions it is required to link this
>> with "rt". Thus I have added
>> performstruct_SYS_LIBS_Linux += rt
>> to pvData/testApp/pv/Makefile.
>> Then I recognized that all the other tests in the Makefile have a line
>> TESTS += ...
>> but performstruct has not. Is this a bug?
>> Dirk
> Hmm.... when adding it to TESTS I get
> $make runtests
> performstruct.t ......... skipped: (no reason given)
> What does this mean?
- Re: Problem with performstruct test Dirk Zimoch
- Problem with performstruct test Dirk Zimoch
<2018>
2025
2026
<2018>
2025
2026
ANJ, 19 Sep 2018 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
