2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: compiler problem in pvData/testApp
To: "Johnson, Andrew N." <[email protected]>, "[email protected]" <[email protected]>
Date: Wed, 26 Sep 2018 10:46:10 -0700
On 09/26/2018 10:01 AM, Johnson, Andrew N. wrote:
> I'm pretty sure this was caused by Marty's adding the pvCopy code to
> pvDatabaseCPP, which includes a similar to but not identical header as
> the one that is still in pvDataCPP and presumably being used by the
> testApp/copy/testPVCopy.cpp source that is also still in pvData.
> I don't have time right now to work out what needs to be removed, Marty
> could you generate a PR to remove pvCopy and the associated test
> program(s) from pvData? I think that's what we need to do to fix this.
I don't have a problem with removing pvCopy now.  Although, as there is
no pressing reason to do otherwise, I was planning on marking it deprecated
for this next release cycle.
Why not rename the conflicting header, or skip installing it?
> - Andrew
> On 09/26/2018 10:39 AM, Dirk Zimoch wrote:
>> Hello,
>> Since last weekend building EPICS 7 fails in pvData/testApp.
>> Can please someone fix this or at least tell me which commit to check
>> out so that I can compile again? Unfortunately I failed to find out what
>> exactly the problem is or which old commit to check out to make it
>> compile again.
>> make[4]: Entering directory
>> `/afs/psi.ch/group/8211/dirk/git/BASE/epics-base-7.0/modules/pvData/testApp/O.RHEL7-x86_64'
>> /usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_64_
>> -DUNIX  -Dlinux     -O3   -Wall           -m64  -I. -I../O.Common -I.
>> -I. -I.. -I../../testApp/misc -I../../testApp/pv
>> -I../../testApp/property -I../../testApp/copy
>> -I/usr/local/epics/base-7.0.1/include/compiler/gcc
>> -I/usr/local/epics/base-7.0.1/include/os/Linux
>> -I/usr/local/epics/base-7.0.1/include        -c
>> ../../testApp/copy/testPVCopy.cpp
>> ../../testApp/copy/testPVCopy.cpp:38:5: error: ‘PVCopyPtr’ has not been
>> declared
>>      PVCopyPtr const & pvCopy)
>> ../../testApp/copy/testPVCopy.cpp: In function ‘void testPVScalar(const
>> string&, const string&, const PVStructurePtr&, const int&)’:
>> ../../testApp/copy/testPVCopy.cpp:48:41: error: base operand of ‘->’ is
>> not a pointer
>>      StructureConstPtr structure = pvCopy->getStructure();
>> ../../testApp/copy/testPVCopy.cpp:49:29: error: base operand of ‘->’ is
>> not a pointer
>>      pvStructureCopy = pvCopy->createPVStructure();
>> ../../testApp/copy/testPVCopy.cpp:52:11: error: base operand of ‘->’ is
>> not a pointer
>>      pvCopy->initCopy(pvStructureCopy, bitSet);
>> ../../testApp/copy/testPVCopy.cpp:56:11: error: base operand of ‘->’ is
>> not a pointer
>>      pvCopy->updateCopySetBitSet(pvStructureCopy,bitSet);
>> ../../testApp/copy/testPVCopy.cpp:60:11: error: base operand of ‘->’ is
>> not a pointer
>>      pvCopy->getCopyOffset(pvValueMaster);
>> ../../testApp/copy/testPVCopy.cpp:67:11: error: base operand of ‘->’ is
>> not a pointer
>>      pvCopy->updateCopyFromBitSet(pvStructureCopy,bitSet);
>> ../../testApp/copy/testPVCopy.cpp:74:11: error: base operand of ‘->’ is
>> not a pointer
>>      pvCopy->updateMaster(pvStructureCopy,bitSet);
>> ../../testApp/copy/testPVCopy.cpp: At global scope:
>> ../../testApp/copy/testPVCopy.cpp:83:5: error: ‘PVCopyPtr’ has not been
>> declared
>> testPVScalarArray(const string&, const string&, const PVStructurePtr&,
>> const int&)’:
>> ../../testApp/copy/testPVCopy.cpp:97:41: error: base operand of ‘->’ is
>> not a pointer
>> ../../testApp/copy/testPVCopy.cpp:99:29: error: base operand of ‘->’ is
>> not a pointer
>> ../../testApp/copy/testPVCopy.cpp:102:11: error: base operand of ‘->’ is
>> not a pointer
>> ../../testApp/copy/testPVCopy.cpp:110:11: error: base operand of ‘->’ is
>> not a pointer
>> ../../testApp/copy/testPVCopy.cpp:114:11: error: base operand of ‘->’ is
>> not a pointer
>> ../../testApp/copy/testPVCopy.cpp:125:11: error: base operand of ‘->’ is
>> not a pointer
>> ../../testApp/copy/testPVCopy.cpp:137:11: error: base operand of ‘->’ is
>> not a pointer
>> ../../testApp/copy/testPVCopy.cpp: In function ‘void scalarTest()’:
>> ../../testApp/copy/testPVCopy.cpp:149:5: error: ‘PVCopyPtr’ was not
>> declared in this scope
>>      PVCopyPtr pvCopy;
>> ../../testApp/copy/testPVCopy.cpp:149:5: note: suggested alternative:
>> In file included from ../../testApp/copy/testPVCopy.cpp:26:0:
>> /usr/local/epics/base-7.0.1/include/pv/pvCopy.h:45:38: note:
>> ‘epics::pvDatabase::PVCopyPtr’
>>  typedef std::tr1::shared_ptr<PVCopy> PVCopyPtr;
>> ../../testApp/copy/testPVCopy.cpp:149:15: error: expected ‘;’ before
>> ‘pvCopy’
>>      PVCopyPtr pvCopy;
>> ../../testApp/copy/testPVCopy.cpp:159:5: error: ‘pvCopy’ was not
>>      pvCopy = PVCopy::create(pvMaster,pvRequest,"");
>> ../../testApp/copy/testPVCopy.cpp:159:14: error: ‘PVCopy’ has not been
>> declared
>> ../../testApp/copy/testPVCopy.cpp:166:14: error: ‘PVCopy’ has not been
>> declared
>> ../../testApp/copy/testPVCopy.cpp:173:14: error: ‘PVCopy’ has not been
>> declared
>> ../../testApp/copy/testPVCopy.cpp: In function ‘void arrayTest()’:
>> ../../testApp/copy/testPVCopy.cpp:186:5: error: ‘PVCopyPtr’ was not
>>      PVCopyPtr pvCopy;
>> ../../testApp/copy/testPVCopy.cpp:186:5: note: suggested alternative:
>> ../../testApp/copy/testPVCopy.cpp:186:15: error: expected ‘;’ before
>> ‘pvCopy’
>>      PVCopyPtr pvCopy;
>> ../../testApp/copy/testPVCopy.cpp:196:5: error: ‘pvCopy’ was not
>> ../../testApp/copy/testPVCopy.cpp:196:14: error: ‘PVCopy’ has not been
>> declared
>> ../../testApp/copy/testPVCopy.cpp:203:14: error: ‘PVCopy’ has not been
>> declared
>> ../../testApp/copy/testPVCopy.cpp:210:14: error: ‘PVCopy’ has not been
>> declared
>> ../../testApp/copy/testPVCopy.cpp: In function ‘void powerSupplyTest()’:
>> ../../testApp/copy/testPVCopy.cpp:251:5: error: ‘PVCopyPtr’ was not
>>      PVCopyPtr pvCopy;
>> ../../testApp/copy/testPVCopy.cpp:251:5: note: suggested alternative:
>> ../../testApp/copy/testPVCopy.cpp:251:15: error: expected ‘;’ before
>> ‘pvCopy’
>>      PVCopyPtr pvCopy;
>> ../../testApp/copy/testPVCopy.cpp:261:5: error: ‘pvCopy’ was not
>> ../../testApp/copy/testPVCopy.cpp:261:14: error: ‘PVCopy’ has not been
>> declared
>> ../../testApp/copy/testPVCopy.cpp:268:14: error: ‘PVCopy’ has not been
>> declared
>> ../../testApp/copy/testPVCopy.cpp:275:14: error: ‘PVCopy’ has not been
>> declared
>> ../../testApp/copy/testPVCopy.cpp:282:14: error: ‘PVCopy’ has not been
>> declared
>> make[4]: *** [testPVCopy.o] Error 1
>> make[4]: Leaving directory
>> In case it matters: I have this problem with several gcc versions, e.g
>> 4.8.5 and 6.2.1. Also with clang, but with better error message:
>> ../../testApp/copy/testPVCopy.cpp:38:5: error: unknown type name
>> 'PVCopyPtr'; did you mean 'epics::pvDatabase::PVCopyPtr'?
>> Thus the problem seems to be namespace related. However I could not find
>> out how to fix it. Using namespace epics::pvDatabase only seems to make
>> things worse.
>> Dirk
compiler problem in pvData/testApp Dirk Zimoch
Re: compiler problem in pvData/testApp Johnson, Andrew N.
Prev: Re: compiler problem in pvData/testApp Johnson, Andrew N.
Next: Build failed in Jenkins: EPICS-7 #111 Jenkins Epics PSI
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Next: Re: compiler problem in pvData/testApp Dirk Zimoch
ANJ, 27 Sep 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
