Hi Andrew,
I have a family of devices which consist of various building blocks.
Different models of the device are made up from a different mix of these
building blocks (some of which require macros and some don't). I'm
trying to build a .db file for each model by pulling the required bits
and pieces together. In the past I used something like the following:
file "a.db" {
file "b.db" {
pattern
{ MACRO1 }
{ "foo" }
{ "bar" }
With EPICS 3.15.6 this doesn't work anymore. I get
msi: Parse error, unexpected '}'
I have to admit that my solution might not be the cleanest approach as
it probably depends on undefined behavior (neither the AppDev guide nor
the MSI website talk about this corner case). I'm wondering if you
consider the change in behavior a bug. I'm able to work around the
problem by using
file "a.db" {
{ DUMMY="" }
Is there a better way to solve my problem?
Thanks a lot,
Martin
P.S.: Seems like the following commit changed the behavior:
https://git.launchpad.net/epics-base/commit/?h=3.15&id=67e2b74758982fd46be5529e28fcb93fd7eb59ad
Martin Konrad
High Performance Controls Team Leader
Facility for Rare Isotope Beams
Michigan State University
640 South Shaw Lane
East Lansing, MI 48824-1321, USA
Tel. 517-908-7253
Email: [email protected]
- Re: Substitution files: change in behavior between 3.15.3 and 3.15.6 Johnson, Andrew N. via Core-talk
Jenkins build is back to normal : epics-base-3.16-win32 #225 APS Jenkins
Build failed in Jenkins: epics-base-3.16-win64 #235 APS Jenkins via Core-talk
<2018>
2025
2026
<2018>
2025
2026
