Hi Martin,
On 10/25/2018 02:44 PM, Konrad, Martin wrote:
> In the past I used something like the following:
> file "a.db" {
> With EPICS 3.15.6 this doesn't work anymore. I get
> msi: Parse error, unexpected '}'
> I have to admit that my solution might not be the cleanest approach as
> it probably depends on undefined behavior (neither the AppDev guide nor
> the MSI website talk about this corner case). I'm wondering if you
> consider the change in behavior a bug. I'm able to work around the
> problem by using
> file "a.db" {
> { DUMMY="" }
> Is there a better way to solve my problem?
> P.S.: Seems like the following commit changed the behavior:
> https://git.launchpad.net/epics-base/commit/?h=3.15&id=67e2b74758982fd46be5529e28fcb93fd7eb59ad
You are right about that commit changing the behaviour, I was fixing a
bug report about the template parser not detecting a syntax error in the
file:
https://bugs.launchpad.net/epics-base/+bug/1503661
Your original usage probably should be legal though, so I'd accept this
change as introducing a bug.
If you want to take a look at msi.c and propose a fix that doesn't
regress the above bug as well I'd be happy to accept it. You should
include a test (in src/ioc/dbtemplate/test, probably by adjusting some
of the existing substitution and result files) that exercises your
behaviour too, to prevent future regressions.
- Andrew
- Substitution files: change in behavior between 3.15.3 and 3.15.6 Konrad, Martin
Re: pvget -m timeout after first value Michael Davidsaver
Jenkins build became unstable: epics-7.0 » linux32 #73 APS Jenkins via Core-talk
<2018>
2025
2026
Build failed in Jenkins: epics-base-3.16-win64 #235 APS Jenkins via Core-talk
<2018>
2025
2026
