2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Subject: group PV question
To: EPICS Core Talk <[email protected]>
Date: Fri, 26 Oct 2018 10:45:33 +0000
I guess this is addressed to Michael but maybe this is a question worth asking in the group:
I am wondering about the difference in group PV atomicity. I tried to follow the circle.db example.
It seems to work as I expected. However, when I use pvget:
$ pvget circle
circle
epics:nt/NTTable:1.0
    structure record
        structure _options
            uint queueSize 0
            boolean atomic true
    double angle 279
    alarm_t alarm NO_ALARM NO_STATUS NO_ALARM
    time_t timeStamp 2018-10-26T12:35:48.132 0
    structure value
        double X 0.156434
        double Y -0.987688
The attribute "atomic" is true, as I expected (set it using info tags). But with monitoring, I get:
circle
    structure record
        structure _options
            uint queueSize 0
            boolean atomic false
    double angle 349
    time_t timeStamp 2018-10-26T12:36:57.948 0
    structure value
        double X 0.981627
        double Y -0.190809
for the same group pv.
Trying to dig into the code (I have not been able to go deep), I see references to "pgatomic" and "monatomic".
This suggests to me that there is a difference in  how monotonicity is set/handled with monitors. Is this true? How can one make groups be handled atomically?
Or is this just my over-interpretation?
I tried to figure this out from the documentation but I could not.
Timo
Re: group PV question Michael Davidsaver
Which version are you using Re: group PV question Kasemir, Kay via Core-talk
Prev: Base 3.16 => 7.0 Merge Johnson, Andrew N. via Core-talk
Next: pvget -m timeout after first value Kasemir, Kay via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Base 3.16 => 7.0 Merge Johnson, Andrew N. via Core-talk
Next: Re: group PV question Michael Davidsaver
ANJ, 29 Oct 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
