Subject: |
Which version are you using Re: group PV question |
"Kasemir, Kay via Core-talk" <[email protected]> |
To: |
EPICS Core Talk <[email protected]> |
Date: |
Mon, 29 Oct 2018 15:57:22 +0000 |
Hello:
Related to Timo's group PV question, I'm looking that the circle.db that's generated with EPICS base 7.0.1.1 when running makeBaseApp.pl -t example.
The structure looks like this, i.e. different from Timo's message:
$ pvinfo training:circle
CHANNEL : training:circle
STATE : CONNECTED
ADDRESS : 160.91.233.125:5075
structure
structure record
structure _options
uint queueSize
boolean atomic
epics:nt/NTScalar:1.0 angle
double value
alarm_t alarm
int severity
int status
string message
time_t timeStamp
long secondsPastEpoch
int nanoseconds
int userTag
display_t display
double limitLow
double limitHigh
string description
string format
string units
control_t control
double limitLow
double limitHigh
double minStep
valueAlarm_t valueAlarm
boolean active
double lowAlarmLimit
double lowWarningLimit
double highWarningLimit
double highAlarmLimit
int lowAlarmSeverity
int lowWarningSeverity
int highWarningSeverity
int highAlarmSeverity
double hysteresis
epics:nt/NTScalar:1.0 x
double value
alarm_t alarm
int severity
int status
string message
time_t timeStamp
int nanoseconds
int userTag
display_t display
double limitLow
double limitHigh
string description
string format
string units
control_t control
double limitLow
double limitHigh
double minStep
boolean active
double hysteresis
epics:nt/NTScalar:1.0 y
double value
alarm_t alarm
int severity
int status
string message
time_t timeStamp
int nanoseconds
int userTag
display_t display
double limitLow
double limitHigh
string description
string format
string units
control_t control
double limitLow
double limitHigh
double minStep
boolean active
double hysteresis
The structure basically contains the complete circle:x, circle:y, circle:angle record data, while Timo had a much more compact example:
From: [email protected] <[email protected]> on behalf of Timo Korhonen <[email protected]>
Sent: Friday, October 26, 2018 6:45 AM
Subject: group PV question
$ pvget circle
circle
epics:nt/NTTable:1.0
structure record
structure _options
uint queueSize 0
boolean atomic true
double angle 279
alarm_t alarm NO_ALARM NO_STATUS NO_ALARM
time_t timeStamp 2018-10-26T12:35:48.132 0
structure value
double X 0.156434
double Y -0.987688
Timo, what are you using to create this? EPICS base 7.0.1.1? git master? Or some older version?
Kay
- Re: Which version are you using Re: group PV question Michael Davidsaver
- Re: Which version are you using Re: group PV question Timo Korhonen
- group PV question Timo Korhonen
Re: pvget -m timeout after first value Kasemir, Kay via Core-talk
Re: pvget -m timeout after first value Michael Davidsaver
<2018>
2025
2026
<2018>
2025
2026
