2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: pvget -m timeout after first value
To: "Kasemir, Kay" <[email protected]>
Cc: EPICS Core Talk <[email protected]>
Date: Mon, 29 Oct 2018 09:05:21 -0700
On 10/29/18 7:49 AM, Kasemir, Kay wrote:
> Hello Michael:
>> By the time this build has failed, the pvtools have already been rebuilt.
>> So you can proceed with testing.
> OK, I've rebuilt the example IOC, and now the response is very consistent:
Good, now we can focus on finding what is probably an actual, underlying, problem.
> [training@training iocExample]$ pvinfo  training:ai1
> training:ai1 Error: channel destroyed
> [training@training iocExample]$ pvget training:ai1
> Timeout
First, repeat these two while adding '-d'.  This will likely produce a lot of output.
If it gets too long, please send as an attachment.
Second.  Run:
> ./modules/pvAccess/examples/O.linux-x86_64/mailbox blah
Then in another terminal run "pvget blah" and "pvinfo blah" and see if they
succeed.
> training:ai1 [training@training iocExample]$ pvget -m training:ai1
> { no printout, just hangs there }
> So instead of one update, and then the timeout, I get nothing,
> and that's now directly within the VM where before it all worked fine.
>> If you would like to see a clean build,
>> then either update the remaining PVA modules as well, or simply delete
>> them.
> I'm unclear which branches from what repositories to combine to get a consistent snapshot.
> I have these:
>>> use branch 'structformatter' in https://github.com/mdavidsaver/pvDataCPP
>>> use branch 'pvtoolsrework' in https://github.com/mdavidsaver/pvAccessCPP
> but what about the other modules/* in base?
> Thanks,
> Kay
Re: pvget -m timeout after first value Kasemir, Kay via Core-talk
Re: pvget -m timeout after first value Michael Davidsaver
Prev: Which version are you using Re: group PV question Kasemir, Kay via Core-talk
Next: Build failed in Jenkins: epics-7.0-windows » STATIC,win32 #62 APS Jenkins via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: pvget -m timeout after first value Kasemir, Kay via Core-talk
Next: Re: pvget -m timeout after first value Kasemir, Kay via Core-talk
ANJ, 29 Oct 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
