Hi!
> First, repeat these two while adding '-d'. This will likely produce a lot of output.
Here's the network setup:
$ /sbin/ifconfig
enp0s3: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 10.0.2.15 netmask 255.255.255.0 broadcast 10.0.2.255
inet6 fe80::7f29:bd96:809b:6dc9 prefixlen 64 scopeid 0x20<link>
ether 08:00:27:c0:85:fe txqueuelen 1000 (Ethernet)
RX packets 22 bytes 5668 (5.5 KiB)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 161 bytes 15518 (15.1 KiB)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536
inet 127.0.0.1 netmask 255.0.0.0
inet6 ::1 prefixlen 128 scopeid 0x10<host>
loop txqueuelen 1000 (Local Loopback)
RX packets 504 bytes 41975 (40.9 KiB)
TX packets 504 bytes 41975 (40.9 KiB)
virbr0: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500
inet 192.168.122.1 netmask 255.255.255.0 broadcast 192.168.122.255
ether 52:54:00:09:e8:c5 txqueuelen 1000 (Ethernet)
RX packets 0 bytes 0 (0.0 B)
TX packets 0 bytes 0 (0.0 B)
PV Info:
$ pvinfo -d training:ai1
2018-10-29T12:28:52.096 Client security plug-in 'ca' installed.
2018-10-29T12:28:52.096 Creating datagram socket from: 0.0.0.0:39127.
2018-10-29T12:28:52.096 Broadcast address #0: 10.0.2.15:5076. (unicast)
2018-10-29T12:28:52.096 Setting up UDP for interface 10.0.2.15/255.255.255.0, broadcast 10.0.2.255, dest <none>.
2018-10-29T12:28:52.096 Creating datagram socket from: 10.0.2.15:5076.
2018-10-29T12:28:52.096 Creating datagram socket from: 10.0.2.255:5076.
2018-10-29T12:28:52.096 Setting up UDP for interface 192.168.122.1/255.255.255.0, broadcast 192.168.122.255, dest <none>.
2018-10-29T12:28:52.097 Creating datagram socket from: 192.168.122.1:5076.
2018-10-29T12:28:52.097 Creating datagram socket from: 192.168.122.255:5076.
2018-10-29T12:28:52.097 Creating datagram socket from: 224.0.0.128:5076.
2018-10-29T12:28:52.097 Local multicast enabled on 127.0.0.1/224.0.0.128:5076.
2018-10-29T12:28:52.097 Sending 58 bytes 0.0.0.0:39127 -> 10.0.2.15:5076.
2018-10-29T12:28:52.097 UDP Rx (58) 10.0.2.15:5076 <- 10.0.2.15:39127
2018-10-29T12:28:52.097 UDP Tx (82) 10.0.2.15:5076 -> 224.0.0.128:5076.
2018-10-29T12:28:52.097 UDP Rx (82) 224.0.0.128:5076 <- 10.0.2.15:5076
training:ai1 Error: channel destroyed
2018-10-29T12:28:52.097 UDP socket 0.0.0.0:0 closed.
2018-10-29T12:28:52.097 UDP Rx (0) 0.0.0.0:39127 <- <Ukn Addr Type>
2018-10-29T12:28:52.097 UDP socket 10.0.2.15:5076 closed.
2018-10-29T12:28:52.097 UDP Rx (0) 10.0.2.15:5076 <- 10.0.2.15:39127
2018-10-29T12:28:52.097 UDP socket 10.0.2.255:5076 closed.
2018-10-29T12:28:52.097 UDP Rx (0) 10.0.2.255:5076 <- <Ukn Addr Type>
2018-10-29T12:28:52.097 UDP socket 192.168.122.1:5076 closed.
2018-10-29T12:28:52.097 UDP Rx (0) 192.168.122.1:5076 <- <Ukn Addr Type>
2018-10-29T12:28:52.097 UDP socket 192.168.122.255:5076 closed.
2018-10-29T12:28:52.097 UDP Rx (0) 192.168.122.255:5076 <- <Ukn Addr Type>
2018-10-29T12:28:52.097 UDP socket 224.0.0.128:5076 closed.
2018-10-29T12:28:52.097 UDP Rx (0) 224.0.0.128:5076 <- 10.0.2.15:5076
PV Get:
$ pvget -d training:ai1
2018-10-29T12:29:26.870 Client security plug-in 'ca' installed.
2018-10-29T12:29:26.871 Creating datagram socket from: 0.0.0.0:54563.
2018-10-29T12:29:26.871 Broadcast address #0: 10.0.2.15:5076. (unicast)
2018-10-29T12:29:26.871 Setting up UDP for interface 10.0.2.15/255.255.255.0, broadcast 10.0.2.255, dest <none>.
2018-10-29T12:29:26.871 Creating datagram socket from: 10.0.2.15:5076.
2018-10-29T12:29:26.871 Creating datagram socket from: 10.0.2.255:5076.
2018-10-29T12:29:26.871 Setting up UDP for interface 192.168.122.1/255.255.255.0, broadcast 192.168.122.255, dest <none>.
2018-10-29T12:29:26.871 Creating datagram socket from: 192.168.122.1:5076.
2018-10-29T12:29:26.871 Creating datagram socket from: 192.168.122.255:5076.
2018-10-29T12:29:26.871 Creating datagram socket from: 224.0.0.128:5076.
2018-10-29T12:29:26.871 Local multicast enabled on 127.0.0.1/224.0.0.128:5076.
2018-10-29T12:29:26.871 Sending 58 bytes 0.0.0.0:54563 -> 10.0.2.15:5076.
2018-10-29T12:29:26.871 UDP Rx (58) 10.0.2.15:5076 <- 10.0.2.15:54563
Waiting...
2018-10-29T12:29:26.871 UDP Tx (82) 10.0.2.15:5076 -> 224.0.0.128:5076.
2018-10-29T12:29:26.871 UDP Rx (82) 224.0.0.128:5076 <- 10.0.2.15:5076
2018-10-29T12:29:27.113 Sending 58 bytes 0.0.0.0:54563 -> 10.0.2.15:5076.
2018-10-29T12:29:27.113 UDP Rx (58) 10.0.2.15:5076 <- 10.0.2.15:54563
2018-10-29T12:29:27.113 UDP Tx (82) 10.0.2.15:5076 -> 224.0.0.128:5076.
2018-10-29T12:29:27.113 UDP Rx (82) 224.0.0.128:5076 <- 10.0.2.15:5076
2018-10-29T12:29:27.585 Sending 58 bytes 0.0.0.0:54563 -> 10.0.2.15:5076.
2018-10-29T12:29:27.585 UDP Rx (58) 10.0.2.15:5076 <- 10.0.2.15:54563
2018-10-29T12:29:27.585 UDP Tx (82) 10.0.2.15:5076 -> 224.0.0.128:5076.
2018-10-29T12:29:27.585 UDP Rx (82) 224.0.0.128:5076 <- 10.0.2.15:5076
2018-10-29T12:29:28.536 Sending 58 bytes 0.0.0.0:54563 -> 10.0.2.15:5076.
2018-10-29T12:29:28.536 UDP Rx (58) 10.0.2.15:5076 <- 10.0.2.15:54563
2018-10-29T12:29:28.536 UDP Tx (82) 10.0.2.15:5076 -> 224.0.0.128:5076.
2018-10-29T12:29:28.536 UDP Rx (82) 224.0.0.128:5076 <- 10.0.2.15:5076
2018-10-29T12:29:30.426 Sending 58 bytes 0.0.0.0:54563 -> 10.0.2.15:5076.
2018-10-29T12:29:30.426 UDP Rx (58) 10.0.2.15:5076 <- 10.0.2.15:54563
2018-10-29T12:29:30.426 UDP Tx (82) 10.0.2.15:5076 -> 224.0.0.128:5076.
2018-10-29T12:29:30.426 UDP Rx (82) 224.0.0.128:5076 <- 10.0.2.15:5076
Timeout
training:ai1 2018-10-29T12:29:31.872 UDP socket 0.0.0.0:0 closed.
2018-10-29T12:29:31.872 UDP Rx (0) 0.0.0.0:54563 <- <Ukn Addr Type>
2018-10-29T12:29:31.872 UDP socket 10.0.2.15:5076 closed.
2018-10-29T12:29:31.872 UDP Rx (0) 10.0.2.15:5076 <- 10.0.2.15:54563
2018-10-29T12:29:31.872 UDP socket 10.0.2.255:5076 closed.
2018-10-29T12:29:31.872 UDP Rx (0) 10.0.2.255:5076 <- <Ukn Addr Type>
2018-10-29T12:29:31.872 UDP socket 192.168.122.1:5076 closed.
2018-10-29T12:29:31.872 UDP Rx (0) 192.168.122.1:5076 <- <Ukn Addr Type>
2018-10-29T12:29:31.872 UDP socket 192.168.122.255:5076 closed.
2018-10-29T12:29:31.872 UDP Rx (0) 192.168.122.255:5076 <- <Ukn Addr Type>
2018-10-29T12:29:31.872 UDP socket 224.0.0.128:5076 closed.
2018-10-29T12:29:31.872 UDP Rx (0) 224.0.0.128:5076 <- 10.0.2.15:5076
Done
> Second. Run:
> > ./modules/pvAccess/examples/O.linux-x86_64/mailbox blah
PV Info:
$ pvinfo -d blah
2018-10-29T12:30:20.791 Client security plug-in 'ca' installed.
2018-10-29T12:30:20.791 Creating datagram socket from: 0.0.0.0:49264.
2018-10-29T12:30:20.791 Broadcast address #0: 10.0.2.15:5076. (unicast)
2018-10-29T12:30:20.791 Setting up UDP for interface 10.0.2.15/255.255.255.0, broadcast 10.0.2.255, dest <none>.
2018-10-29T12:30:20.791 Creating datagram socket from: 10.0.2.15:5076.
2018-10-29T12:30:20.791 Creating datagram socket from: 10.0.2.255:5076.
2018-10-29T12:30:20.792 Setting up UDP for interface 192.168.122.1/255.255.255.0, broadcast 192.168.122.255, dest <none>.
2018-10-29T12:30:20.792 Creating datagram socket from: 192.168.122.1:5076.
2018-10-29T12:30:20.792 Creating datagram socket from: 192.168.122.255:5076.
2018-10-29T12:30:20.792 Creating datagram socket from: 224.0.0.128:5076.
2018-10-29T12:30:20.792 Local multicast enabled on 127.0.0.1/224.0.0.128:5076.
2018-10-29T12:30:20.792 Sending 50 bytes 0.0.0.0:49264 -> 10.0.2.15:5076.
2018-10-29T12:30:20.792 UDP Rx (50) 10.0.2.15:5076 <- 10.0.2.15:49264
2018-10-29T12:30:20.792 UDP Tx (74) 10.0.2.15:5076 -> 224.0.0.128:5076.
2018-10-29T12:30:20.792 UDP Rx (53) 0.0.0.0:49264 <- 10.0.2.15:48448
2018-10-29T12:30:20.792 UDP Rx (74) 224.0.0.128:5076 <- 10.0.2.15:5076
blah Error: channel destroyed
2018-10-29T12:30:20.792 UDP socket 0.0.0.0:0 closed.
2018-10-29T12:30:20.792 Connecting to PVA server: 10.0.2.15:5075.
2018-10-29T12:30:20.792 Opening socket to PVA server 10.0.2.15:5075, attempt 1.
2018-10-29T12:30:20.792 Socket connected to PVA server: 10.0.2.15:5075.
2018-10-29T12:30:20.792 Acquiring transport to 10.0.2.15:5075.
2018-10-29T12:30:20.793 Connected to PVA server: 10.0.2.15:5075.
2018-10-29T12:30:20.793 UDP socket 10.0.2.15:5076 closed.
2018-10-29T12:30:20.793 UDP Rx (0) 10.0.2.15:5076 <- 10.0.2.15:49264
2018-10-29T12:30:20.793 UDP socket 10.0.2.255:5076 closed.
2018-10-29T12:30:20.793 UDP Rx (0) 10.0.2.255:5076 <- <Ukn Addr Type>
2018-10-29T12:30:20.793 UDP socket 192.168.122.1:5076 closed.
2018-10-29T12:30:20.793 UDP Rx (0) 192.168.122.1:5076 <- <Ukn Addr Type>
2018-10-29T12:30:20.793 UDP socket 192.168.122.255:5076 closed.
2018-10-29T12:30:20.793 UDP Rx (0) 192.168.122.255:5076 <- <Ukn Addr Type>
2018-10-29T12:30:20.793 UDP socket 224.0.0.128:5076 closed.
2018-10-29T12:30:20.793 UDP Rx (0) 224.0.0.128:5076 <- 10.0.2.15:5076
2018-10-29T12:30:21.993 PVA client context destroyed with 1 transport(s) active.
PV Get:
$ pvget -d blah
2018-10-29T12:30:40.584 Client security plug-in 'ca' installed.
2018-10-29T12:30:40.585 Creating datagram socket from: 0.0.0.0:38927.
2018-10-29T12:30:40.585 Broadcast address #0: 10.0.2.15:5076. (unicast)
2018-10-29T12:30:40.585 Setting up UDP for interface 10.0.2.15/255.255.255.0, broadcast 10.0.2.255, dest <none>.
2018-10-29T12:30:40.585 Creating datagram socket from: 10.0.2.15:5076.
2018-10-29T12:30:40.585 Creating datagram socket from: 10.0.2.255:5076.
2018-10-29T12:30:40.585 Setting up UDP for interface 192.168.122.1/255.255.255.0, broadcast 192.168.122.255, dest <none>.
2018-10-29T12:30:40.585 Creating datagram socket from: 192.168.122.1:5076.
2018-10-29T12:30:40.585 Creating datagram socket from: 192.168.122.255:5076.
2018-10-29T12:30:40.585 Creating datagram socket from: 224.0.0.128:5076.
2018-10-29T12:30:40.585 Local multicast enabled on 127.0.0.1/224.0.0.128:5076.
2018-10-29T12:30:40.585 Sending 50 bytes 0.0.0.0:38927 -> 10.0.2.15:5076.
2018-10-29T12:30:40.585 UDP Rx (50) 10.0.2.15:5076 <- 10.0.2.15:38927
Waiting...
2018-10-29T12:30:40.585 UDP Tx (74) 10.0.2.15:5076 -> 224.0.0.128:5076.
2018-10-29T12:30:40.585 UDP Rx (74) 224.0.0.128:5076 <- 10.0.2.15:5076
2018-10-29T12:30:40.585 UDP Rx (53) 0.0.0.0:38927 <- 10.0.2.15:48448
2018-10-29T12:30:40.585 Connecting to PVA server: 10.0.2.15:5075.
2018-10-29T12:30:40.585 Opening socket to PVA server 10.0.2.15:5075, attempt 1.
2018-10-29T12:30:40.585 Socket connected to PVA server: 10.0.2.15:5075.
2018-10-29T12:30:40.586 Acquiring transport to 10.0.2.15:5075.
2018-10-29T12:30:40.586 Connected to PVA server: 10.0.2.15:5075.
blah
2018-10-29T12:30:40.586 Releasing TCP transport to 10.0.2.15:5075.
2018-10-29T12:30:40.586 TCP socket to 10.0.2.15:5075 is to be closed.
2018-10-29T12:30:40.586 UDP socket 0.0.0.0:0 closed.
2018-10-29T12:30:40.586 UDP Rx (0) 0.0.0.0:38927 <- 10.0.2.15:48448
2018-10-29T12:30:40.586 UDP socket 10.0.2.15:5076 closed.
2018-10-29T12:30:40.586 UDP Rx (0) 10.0.2.15:5076 <- 10.0.2.15:38927
2018-10-29T12:30:40.586 UDP socket 10.0.2.255:5076 closed.
2018-10-29T12:30:40.586 UDP Rx (0) 10.0.2.255:5076 <- <Ukn Addr Type>
2018-10-29T12:30:40.587 UDP socket 192.168.122.1:5076 closed.
2018-10-29T12:30:40.587 UDP Rx (0) 192.168.122.1:5076 <- <Ukn Addr Type>
2018-10-29T12:30:40.587 UDP socket 192.168.122.255:5076 closed.
2018-10-29T12:30:40.587 UDP Rx (0) 192.168.122.255:5076 <- <Ukn Addr Type>
2018-10-29T12:30:40.587 UDP socket 224.0.0.128:5076 closed.
2018-10-29T12:30:40.587 UDP Rx (0) 224.0.0.128:5076 <- 10.0.2.15:5076
Done
-Kay
- Re: pvget -m timeout after first value Michael Davidsaver
- pvget -m timeout after first value Kasemir, Kay via Core-talk
- Re: pvget -m timeout after first value Kasemir, Kay via Core-talk
Build failed in Jenkins: epics-7.0-windows » STATIC,win64 #62 APS Jenkins via Core-talk
Re: Which version are you using Re: group PV question Michael Davidsaver
<2018>
2025
2026
<2018>
2025
2026
