On 10/29/18 8:57 AM, Kasemir, Kay via Core-talk wrote:
> Hello:
> Related to Timo's group PV question, I'm looking that the circle.db that's generated with EPICS base 7.0.1.1 when running makeBaseApp.pl -t example.
I didn't realize circle.db was in any template... The present incarnation is:
https://github.com/epics-base/pva2pva/blob/master/iocBoot/iocwfdemo/iq.db
> The structure looks like this, i.e. different from Timo's message:
I'm guessing he has changed it to something which is almost an NTTable. Like:
https://github.com/epics-base/pva2pva/blob/master/iocBoot/iocimagedemo/table.db
> $ pvinfo training:circle
> CHANNEL : training:circle
> STATE : CONNECTED
> ADDRESS : 160.91.233.125:5075
> structure
> structure record
> structure _options
> uint queueSize
> boolean atomic
> epics:nt/NTScalar:1.0 angle
> double value
> alarm_t alarm
> int severity
> int status
> string message
> time_t timeStamp
> long secondsPastEpoch
> int nanoseconds
> int userTag
> display_t display
> double limitLow
> double limitHigh
> string description
> string format
> string units
> control_t control
> double limitLow
> double limitHigh
> double minStep
> valueAlarm_t valueAlarm
> boolean active
> double lowAlarmLimit
> double lowWarningLimit
> double highWarningLimit
> double highAlarmLimit
> int lowAlarmSeverity
> int lowWarningSeverity
> int highWarningSeverity
> int highAlarmSeverity
> double hysteresis
> epics:nt/NTScalar:1.0 x
> double value
> alarm_t alarm
> int severity
> int status
> string message
> time_t timeStamp
> int nanoseconds
> int userTag
> display_t display
> double limitLow
> double limitHigh
> string description
> string format
> string units
> control_t control
> double limitLow
> double limitHigh
> double minStep
> boolean active
> double hysteresis
> epics:nt/NTScalar:1.0 y
> double value
> alarm_t alarm
> int severity
> int status
> string message
> time_t timeStamp
> int nanoseconds
> int userTag
> display_t display
> double limitLow
> double limitHigh
> string description
> string format
> string units
> control_t control
> double limitLow
> double limitHigh
> double minStep
> boolean active
> double hysteresis
> The structure basically contains the complete circle:x, circle:y, circle:angle record data, while Timo had a much more compact example:
> From: [email protected] <[email protected]> on behalf of Timo Korhonen <[email protected]>
> Sent: Friday, October 26, 2018 6:45 AM
> Subject: group PV question
> $ pvget circle
> circle
> epics:nt/NTTable:1.0
> structure record
> structure _options
> uint queueSize 0
> boolean atomic true
> double angle 279
> alarm_t alarm NO_ALARM NO_STATUS NO_ALARM
> time_t timeStamp 2018-10-26T12:35:48.132 0
> structure value
> double X 0.156434
> double Y -0.987688
> Timo, what are you using to create this? EPICS base 7.0.1.1? git master? Or some older version?
> Thanks,
> Kay
- group PV question Timo Korhonen
- Which version are you using Re: group PV question Kasemir, Kay via Core-talk
Re: pvget -m timeout after first value Kasemir, Kay via Core-talk
<2018>
2025
2026
Re: Which version are you using Re: group PV question Timo Korhonen
<2018>
2025
2026
