2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: pvget -m timeout after first value
From: "Kasemir, Kay via Core-talk" <[email protected]>
To: Michael Davidsaver <[email protected]>
Cc: EPICS Core Talk <[email protected]>
Date: Mon, 29 Oct 2018 16:41:33 +0000
>> By the time this build has failed, the pvtools have already been rebuilt.
>> So you can proceed with testing.
> OK, I've rebuilt the example IOC,..
Actually, something must be missing.
Before, the IOC knew about a "pvasr" command.
Now it doesn't.
So I guess the EPICS base build failed a little too early,
and the example IOC simply doesn't contain the PVA server any more.
-> I need a complete set of EPICS base sources that compiles without errors.
-Kay
Re: pvget -m timeout after first value Johnson, Andrew N. via Core-talk
pvget -m timeout after first value Kasemir, Kay via Core-talk
Re: pvget -m timeout after first value Michael Davidsaver
Re: pvget -m timeout after first value Kasemir, Kay via Core-talk
Prev: Re: Which version are you using Re: group PV question Michael Davidsaver
Next: Re: pvget -m timeout after first value Michael Davidsaver
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: pvget -m timeout after first value Kasemir, Kay via Core-talk
Next: Re: pvget -m timeout after first value Johnson, Andrew N. via Core-talk
ANJ, 30 Oct 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
