Hi Mike,
thank you for your mail.
On 11/6/18 7:00 PM, Michael Davidsaver wrote:
How did you get this toolchain? I'm wondering if you have some "contamination"
from other/newer toolchains?
The usual way but with branch 4.10 instead of master.
git clone git://git.rtems.org/rtems.git
git clone git://git.rtems.org/rtems-tools.git
git clone git://git.rtems.org/rtems-source-builder.git
cd into rtems: git checkout origin/4.10
cd into rtems-tools: git checkout origin/4.10
cd into rtems-source-builder: git checkout origin/4.10
waf configure --prefix=/home/h1/RTEMS/rtems/4.10 build install
source-builder/sb-set-builder --log log.i386.4.10.log
--prefix=/home/h1/RTEMS/rtems/4.10 4.10/rtems-i386
rtems-source-builder/source-builder/sb-bootstrap
rtems/configure --enable-maintainer-mode
--prefix=/home/h1/RTEMS/rtems/4.10 --target=i386-rtems4.10
--enable-rtemsbsp="pc386" --enable-cxx --enable-networking
--enable-tests=samples
In RTEMS/rtems/4.10/i386-rtems4.10/pc386/lib/include/rtems/score/thread.h
real_priority is defined in struct Thread_Priority_node
* @brief Encapsulates base and inherited priority.
typedef struct Thread_Priority_node {
Chain_Node Node;
/** current priority = min(real_priority, min(Inherited_priorities)) */
Priority_Control current_priority;
/** base priority irrespective of inheritance/ceiling */
Priority_Control real_priority;
/** NULL if not waiting, or the mutex blocked upon
* if waiting. If not NULL, then this Priority_node is on the mutex
holder's
* Priority_node.Inherited_priorities list. */
struct CORE_mutex_Control *waiting_to_hold;
/** Priority Queue of thread Priority_nodes blocked by this one, thus
* possibly contributing their priority to the current_priority. */
Chain_Control Inherited_priorities;
} Thread_Priority_node;
I will investigate further,
Heinz
If you want you can try to test using the pre-built toolchain I created for the travis-ci builder.
These are built for use in an Ubuntu Linux environment.
https://github.com/mdavidsaver/rsb/releases
In this toolchain the Thread_Control struct is
/home/travis/.rtems/i386-rtems4.10/pc386/lib/include/rtems/score/thread.h
and 'real_priority' and 'current_priority' are unconditional members.
On 11/6/18 9:44 AM, Heinz P. Junkes wrote:
Try to compile epics-base against rtems 4.10 for i368 target (pc368) and get
/home/h1/RTEMS/rtems/4.10/bin/i386-rtems4.10-gcc --pipe -B/home/h1/RTEMS/rtems/4.10/i386-rtems4.10/pc386/lib/ -specs bsp_specs -qrtems -fasm -mtune=i386 -DUNIX -O2 -g -g -Wall -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/RTEMS -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I/home/h1/WIP/EPICS_PORT/4.10/epics-base/epics-base/include/compiler/gcc -I/home/h1/WIP/EPICS_PORT/4.10/epics-base/epics-base/include/os/RTEMS
-I/home/h1/WIP/EPICS_PORT/4.10/epics-base/epics-base/include -I/home/h1/WIP/EPICS_PORT/4.10/epics-base/epics-base/include/compiler/gcc -I/home/h1/WIP/EPICS_PORT/4.10/epics-base/epics-base/include/os/RTEMS -I/home/h1/WIP/EPICS_PORT/4.10/epics-base/epics-base/include -c ../../src/osi/os/RTEMS/osdThread.c
../../src/osi/os/RTEMS/osdThread.c: In function 'showInternalTaskInfo':
../../src/osi/os/RTEMS/osdThread.c:643: error: 'Thread_Control' has no member named 'real_priority'
../../src/osi/os/RTEMS/osdThread.c:650: error: 'Thread_Control' has no member named 'current_priority'
../../src/osi/os/RTEMS/osdThread.c:650: error: 'Thread_Control' has no member named 'real_priority'
../../src/osi/os/RTEMS/osdThread.c:651: error: 'Thread_Control' has no member named 'current_priority'
../../src/osi/os/RTEMS/osdThread.c:653: error: 'Thread_Control' has no member named 'real_priority'
../../src/osi/os/RTEMS/osdThread.c:653: error: 'Thread_Control' has no member named 'current_priority'
/home/h1/WIP/EPICS_PORT/4.10/epics-base/epics-base/configure/RULES_BUILD:232: recipe for target 'osdThread.o' failed
make[4]: *** [osdThread.o] Error 1
Heinz
11/3/18 12:12 PM, Heinz Junkes wrote:
Hello friends,
unfortunately, it's only now that I get back to taking care of rtems-5 for epics-base.
And unfortunately, I haven't really taken care of travis-ci yet. I found the last "travis-run” for rtems 4.10:
https://travis-ci.org/epics-base/epics-base/jobs/450069785.
I'm going to try to replay this on my computer first.
Do I see it right that I should then try to do exactly that with rtems-5. So on the qemu-system-x86 with the rtems i386 bsp?
The next step would then be on my hardware mvme6100? And maybe also on the qemu for mvme3100?
@Michael: Can you write me again where I can get the qemu mvme3100 from?
I'll try my luck and hope to make it to Melbourne.
Heinz
Das FHI verarbeitet, speichert und loescht Daten im Rahmen seiner
Geschaeftstaetigkeit gemaess der Datenschutz-Grundverordnung (DSGVO)
[General Data Protection Regulation (GDPR)] der Europaeischen Union.
- Re: RTEMS5 with epics-base Michael Davidsaver
- RTEMS5 with epics-base Heinz Junkes
- Re: RTEMS5 with epics-base Heinz P. Junkes
<2018>
2025
2026
<2018>
2025
2026
