On 11/6/18 11:07 AM, Heinz P. Junkes wrote:
> Hi Mike,
> thank you for your mail.
> On 11/6/18 7:00 PM, Michael Davidsaver wrote:
>> How did you get this toolchain? I'm wondering if you have some "contamination"
>> from other/newer toolchains?
> The usual way but with branch 4.10 instead of master.
Ha, what "usual" way? My recipe differs from this.
https://github.com/mdavidsaver/rsb/blob/4.10/.ci/build.sh
I was going to suggest that you try to run this yourself, but then I noticed
that the most recent travis-ci run had failed because a source file
http://www.multiprecision.org/mpc/download/mpc-0.8.1.tar.gz
has vanished (now a 500).
This may be fixed on the 4.10 branch of the upstream rsb repository,
but I don't have the patience to update right now. The rtems-source-builder
has been nothing but trouble for me. Old version or new, it seems to be
perpetually broken in one way or the other.
> git clone git://git.rtems.org/rtems.git
> git clone git://git.rtems.org/rtems-tools.git
> git clone git://git.rtems.org/rtems-source-builder.git
> cd into rtems: git checkout origin/4.10
> cd into rtems-tools: git checkout origin/4.10
> cd into rtems-source-builder: git checkout origin/4.10
> waf configure --prefix=/home/h1/RTEMS/rtems/4.10 build install
> source-builder/sb-set-builder --log log.i386.4.10.log --prefix=/home/h1/RTEMS/rtems/4.10 4.10/rtems-i386
> rtems-source-builder/source-builder/sb-bootstrap
> rtems/configure --enable-maintainer-mode --prefix=/home/h1/RTEMS/rtems/4.10 --target=i386-rtems4.10 --enable-rtemsbsp="pc386" --enable-cxx --enable-networking --enable-tests=samples
> In RTEMS/rtems/4.10/i386-rtems4.10/pc386/lib/include/rtems/score/thread.h
> real_priority is defined in struct Thread_Priority_node
> * @brief Encapsulates base and inherited priority.
> typedef struct Thread_Priority_node {
> Chain_Node Node;
> /** current priority = min(real_priority, min(Inherited_priorities)) */
> Priority_Control current_priority;
> /** base priority irrespective of inheritance/ceiling */
> Priority_Control real_priority;
> /** NULL if not waiting, or the mutex blocked upon
> * if waiting. If not NULL, then this Priority_node is on the mutex holder's
> * Priority_node.Inherited_priorities list. */
> struct CORE_mutex_Control *waiting_to_hold;
> /** Priority Queue of thread Priority_nodes blocked by this one, thus
> * possibly contributing their priority to the current_priority. */
> Chain_Control Inherited_priorities;
> } Thread_Priority_node;
> I will investigate further,
> Heinz
>> If you want you can try to test using the pre-built toolchain I created for the travis-ci builder.
>> These are built for use in an Ubuntu Linux environment.
>> https://github.com/mdavidsaver/rsb/releases
>> In this toolchain the Thread_Control struct is
>> /home/travis/.rtems/i386-rtems4.10/pc386/lib/include/rtems/score/thread.h
>> and 'real_priority' and 'current_priority' are unconditional members.
>> On 11/6/18 9:44 AM, Heinz P. Junkes wrote:
>>> Try to compile epics-base against rtems 4.10 for i368 target (pc368) and get
>>> /home/h1/RTEMS/rtems/4.10/bin/i386-rtems4.10-gcc --pipe -B/home/h1/RTEMS/rtems/4.10/i386-rtems4.10/pc386/lib/ -specs bsp_specs -qrtems -fasm -mtune=i386 -DUNIX -O2 -g -g -Wall -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/RTEMS -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I/home/h1/WIP/EPICS_PORT/4.10/epics-base/epics-base/include/compiler/gcc -I/home/h1/WIP/EPICS_PORT/4.10/epics-base/epics-base/include/os/RTEMS
>>> -I/home/h1/WIP/EPICS_PORT/4.10/epics-base/epics-base/include -I/home/h1/WIP/EPICS_PORT/4.10/epics-base/epics-base/include/compiler/gcc -I/home/h1/WIP/EPICS_PORT/4.10/epics-base/epics-base/include/os/RTEMS -I/home/h1/WIP/EPICS_PORT/4.10/epics-base/epics-base/include -c ../../src/osi/os/RTEMS/osdThread.c
>>> ../../src/osi/os/RTEMS/osdThread.c: In function 'showInternalTaskInfo':
>>> ../../src/osi/os/RTEMS/osdThread.c:643: error: 'Thread_Control' has no member named 'real_priority'
>>> ../../src/osi/os/RTEMS/osdThread.c:650: error: 'Thread_Control' has no member named 'current_priority'
>>> ../../src/osi/os/RTEMS/osdThread.c:650: error: 'Thread_Control' has no member named 'real_priority'
>>> ../../src/osi/os/RTEMS/osdThread.c:651: error: 'Thread_Control' has no member named 'current_priority'
>>> ../../src/osi/os/RTEMS/osdThread.c:653: error: 'Thread_Control' has no member named 'real_priority'
>>> ../../src/osi/os/RTEMS/osdThread.c:653: error: 'Thread_Control' has no member named 'current_priority'
>>> /home/h1/WIP/EPICS_PORT/4.10/epics-base/epics-base/configure/RULES_BUILD:232: recipe for target 'osdThread.o' failed
>>> make[4]: *** [osdThread.o] Error 1
>>> Heinz
>>> 11/3/18 12:12 PM, Heinz Junkes wrote:
>>>> Hello friends,
>>>> unfortunately, it's only now that I get back to taking care of rtems-5 for epics-base.
>>>> And unfortunately, I haven't really taken care of travis-ci yet. I found the last "travis-run” for rtems 4.10:
>>>> https://travis-ci.org/epics-base/epics-base/jobs/450069785.
>>>> I'm going to try to replay this on my computer first.
>>>> Do I see it right that I should then try to do exactly that with rtems-5. So on the qemu-system-x86 with the rtems i386 bsp?
>>>> The next step would then be on my hardware mvme6100? And maybe also on the qemu for mvme3100?
>>>> @Michael: Can you write me again where I can get the qemu mvme3100 from?
>>>> I'll try my luck and hope to make it to Melbourne.
>>>> Heinz
>>> Das FHI verarbeitet, speichert und loescht Daten im Rahmen seiner
>>> Geschaeftstaetigkeit gemaess der Datenschutz-Grundverordnung (DSGVO)
>>> [General Data Protection Regulation (GDPR)] der Europaeischen Union.
- Re: RTEMS5 with epics-base Heinz P. Junkes
- RTEMS5 with epics-base Heinz Junkes
- Re: RTEMS5 with epics-base Michael Davidsaver
Re: Problem with cross-tests Johnson, Andrew N. via Core-talk
<2018>
2025
2026
<2018>
2025
2026
