2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Problem with cross-tests
From: "Johnson, Andrew N. via Core-talk" <[email protected]>
Date: Tue, 6 Nov 2018 20:52:30 +0000
Hi Dirk,
On 11/2/18 6:02 AM, Dirk Zimoch wrote:
> I have some architectures in my CROSS_COMPILER_RUNTEST_ARCHS and some of
> their "dbtemplate" tests fail with the error message:
> Can't exec "./msi-copy": No such file or directory at msi.t line 77.
> It seems "msi-copy" is only created for the EPICS_HOST_ARCH, but not for
> all CROSS_COMPILER_RUNTEST_ARCHS.
> In src/ioc/dbtemplate/test/Makefile, I find:
> TARGETS_HOST += msi-copy$(EXE)
> This seems not sufficient. I have not found out yet what to use instead.
> "msi" had been build for all my Linux targets, including those in
The msi-copy executable was a bit of a hack; it was needed so the msi.t
script could find an msi program to be tested. On the base-7.0 branch I
have modified the install rule that generates .t files from .plt sources
so they can now use @TOP@ and @ARCH@ which get replaced when the .t file
is built. As a result I deleted the msi-copy target because the script
can now run msi directly from the @TOP@/bin/@ARCH@ directory.
I think this fix should work for earlier branches, please test it when
you get a chance:
> index fb03b54..dc73eac 100644
> --- a/src/ioc/dbtemplate/test/Makefile
> +++ b/src/ioc/dbtemplate/test/Makefile
> @@ -17,8 +17,9 @@ TESTS += msi
>  TESTSCRIPTS_HOST += $(TESTS:%=%.t)
> -TARGETS_HOST += msi-copy$(EXE)
> -TARGETS += $(TARGETS_$(BUILD_CLASS))
> +ifneq (,$(findstring $(T_A),$(EPICS_HOST_ARCH) $(CROSS_COMPILER_RUNTEST_ARCHS)))
> +  TARGETS += msi-copy$(EXE)
> +endif
>  include $(TOP)/configure/RULES
- Andrew
Re: Problem with cross-tests Dirk Zimoch
Prev: Re: RTEMS5 with epics-base Michael Davidsaver
Next: Re: RTEMS5 with epics-base Heinz P. Junkes
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Prev: Problem with cross-tests Dirk Zimoch
Next: Re: Problem with cross-tests Dirk Zimoch
ANJ, 08 Nov 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
