2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: RTEMS5 with epics-base
To: Michael Davidsaver <[email protected]>
Cc: EPICS Core Talk <[email protected]>
Date: Wed, 7 Nov 2018 16:02:25 +0100
they changed the Thread_Control_struct
I applied the following changes to epics-base:
diff --git a/modules/libcom/src/osi/os/RTEMS/osdThread.c b/modules/libcom/src/osi/os/RTEMS/osdThread.c
index 769e958..2db1ca5 100644
--- a/modules/libcom/src/osi/os/RTEMS/osdThread.c
+++ b/modules/libcom/src/osi/os/RTEMS/osdThread.c
@@ -640,17 +640,17 @@ showInternalTaskInfo (rtems_id tid)
      * that priority should be displayed, not the value truncated to
      * the EPICS range.
-    epicsPri = 199-thread.real_priority;
+    epicsPri = 199-thread.Priority_node.real_priority;
     if (epicsPri < 0)
         fprintf(epicsGetStdout(),"   <0");
     else if (epicsPri > 99)
         fprintf(epicsGetStdout(),"  >99");
     else
         fprintf(epicsGetStdout()," %4d", epicsPri);
-    if (thread.current_priority == thread.real_priority)
-        fprintf(epicsGetStdout(),"%4d    ", (int)thread.current_priority);
+    if (thread.Priority_node.current_priority == thread.Priority_node.real_priority) +        fprintf(epicsGetStdout(),"%4d    ", (int)thread.Priority_node.current_priority);
     else
-        fprintf(epicsGetStdout(),"%4d/%-3d", (int)thread.real_priority, (int)thread.current_priority); +        fprintf(epicsGetStdout(),"%4d/%-3d", (int)thread.Priority_node.real_priority, (int)thread.Priority_node.current_priority);
     showBitmap (bitbuf, thread.current_state, taskState);
     fprintf(epicsGetStdout(),"%8.8s", bitbuf);
     if (thread.current_state & (STATES_WAITING_FOR_SEMAPHORE |
On 11/6/18 8:21 PM, Michael Davidsaver wrote:
On 11/6/18 11:07 AM, Heinz P. Junkes wrote:
Hi Mike,
thank you for your mail.
On 11/6/18 7:00 PM, Michael Davidsaver wrote:
How did you get this toolchain?  I'm wondering if you have some "contamination"
from other/newer toolchains?
The usual way but with branch 4.10 instead of master.
Ha, what "usual" way?  My recipe differs from this.
https://github.com/mdavidsaver/rsb/blob/4.10/.ci/build.sh
I was going to suggest that you try to run this yourself, but then I noticed
that the most recent travis-ci run had failed because a source file
http://www.multiprecision.org/mpc/download/mpc-0.8.1.tar.gz
has vanished (now a 500).
This may be fixed on the 4.10 branch of the upstream rsb repository,
but I don't have the patience to update right now.  The rtems-source-builder
has been nothing but trouble for me.  Old version or new, it seems to be
perpetually broken in one way or the other.
git clone git://git.rtems.org/rtems.git
git clone git://git.rtems.org/rtems-tools.git
git clone git://git.rtems.org/rtems-source-builder.git
cd into rtems: git checkout origin/4.10
cd into rtems-tools: git checkout origin/4.10
cd into rtems-source-builder: git checkout origin/4.10
waf configure --prefix=/home/h1/RTEMS/rtems/4.10 build install
source-builder/sb-set-builder --log log.i386.4.10.log --prefix=/home/h1/RTEMS/rtems/4.10 4.10/rtems-i386
rtems-source-builder/source-builder/sb-bootstrap
rtems/configure --enable-maintainer-mode --prefix=/home/h1/RTEMS/rtems/4.10 --target=i386-rtems4.10 --enable-rtemsbsp="pc386" --enable-cxx --enable-networking --enable-tests=samples
In RTEMS/rtems/4.10/i386-rtems4.10/pc386/lib/include/rtems/score/thread.h
real_priority is defined in struct Thread_Priority_node
  * @brief Encapsulates base and inherited priority.
typedef struct Thread_Priority_node {
   Chain_Node                   Node;
   /** current priority = min(real_priority, min(Inherited_priorities)) */
   Priority_Control             current_priority;
   /** base priority irrespective of inheritance/ceiling */
   Priority_Control             real_priority;
   /** NULL if not waiting, or the mutex blocked upon
    * if waiting. If not NULL, then this Priority_node is on the mutex holder's
    * Priority_node.Inherited_priorities list. */
   struct CORE_mutex_Control   *waiting_to_hold;
   /** Priority Queue of thread Priority_nodes blocked by this one, thus
    * possibly contributing their priority to the current_priority. */
   Chain_Control                Inherited_priorities;
} Thread_Priority_node;
I will investigate further,
Heinz
If you want you can try to test using the pre-built toolchain I created for the travis-ci builder.
These are built for use in an Ubuntu Linux environment.
https://github.com/mdavidsaver/rsb/releases
In this toolchain the Thread_Control struct is
/home/travis/.rtems/i386-rtems4.10/pc386/lib/include/rtems/score/thread.h
and 'real_priority' and 'current_priority' are unconditional members.
On 11/6/18 9:44 AM, Heinz P. Junkes wrote:
Try to compile epics-base against rtems 4.10 for i368 target (pc368) and get
/home/h1/RTEMS/rtems/4.10/bin/i386-rtems4.10-gcc --pipe -B/home/h1/RTEMS/rtems/4.10/i386-rtems4.10/pc386/lib/ -specs bsp_specs -qrtems   -fasm   -mtune=i386 -DUNIX      -O2 -g -g   -Wall           -I. -I../O.Common -I. -I../../src/osi/compiler/gcc -I../../src/osi/compiler/default -I. -I../../src/osi/os/RTEMS -I../../src/osi/os/posix -I../../src/osi/os/default -I.. -I../../src/as -I../../src/bucketLib -I../../src/calc -I../../src/cvtFast -I../../src/cppStd -I../../src/cxxTemplates -I../../src/dbmf -I../../src/ellLib -I../../src/env -I../../src/error -I../../src/fdmgr -I../../src/flex -I../../src/freeList -I../../src/gpHash -I../../src/iocsh -I../../src/log -I../../src/macLib -I../../src/misc -I../../src/osi -I../../src/pool -I../../src/ring -I../../src/taskwd -I../../src/timer -I../../src/yacc -I../../src/yacc -I../../src/yajl -I/home/h1/WIP/EPICS_PORT/4.10/epics-base/epics-base/include/compiler/gcc -I/home/h1/WIP/EPICS_PORT/4.10/epics-base/epics-base/include/os/RTEMS
-I/home/h1/WIP/EPICS_PORT/4.10/epics-base/epics-base/include -I/home/h1/WIP/EPICS_PORT/4.10/epics-base/epics-base/include/compiler/gcc -I/home/h1/WIP/EPICS_PORT/4.10/epics-base/epics-base/include/os/RTEMS -I/home/h1/WIP/EPICS_PORT/4.10/epics-base/epics-base/include -c ../../src/osi/os/RTEMS/osdThread.c
../../src/osi/os/RTEMS/osdThread.c: In function 'showInternalTaskInfo':
../../src/osi/os/RTEMS/osdThread.c:643: error: 'Thread_Control' has no member named 'real_priority'
../../src/osi/os/RTEMS/osdThread.c:650: error: 'Thread_Control' has no member named 'current_priority'
../../src/osi/os/RTEMS/osdThread.c:650: error: 'Thread_Control' has no member named 'real_priority'
../../src/osi/os/RTEMS/osdThread.c:651: error: 'Thread_Control' has no member named 'current_priority'
../../src/osi/os/RTEMS/osdThread.c:653: error: 'Thread_Control' has no member named 'real_priority'
../../src/osi/os/RTEMS/osdThread.c:653: error: 'Thread_Control' has no member named 'current_priority'
/home/h1/WIP/EPICS_PORT/4.10/epics-base/epics-base/configure/RULES_BUILD:232: recipe for target 'osdThread.o' failed
make[4]: *** [osdThread.o] Error 1
Heinz
    11/3/18 12:12 PM, Heinz Junkes wrote:
Hello friends,
unfortunately, it's only now that I get back to taking care of rtems-5 for epics-base.
And unfortunately, I haven't really taken care of travis-ci yet. I found the last "travis-run” for rtems 4.10:
https://travis-ci.org/epics-base/epics-base/jobs/450069785.
I'm going to try to replay this on my computer first.
Do I see it right that I should then try to do exactly that with rtems-5. So on the qemu-system-x86 with the rtems i386 bsp?
The next step would then be on my hardware mvme6100? And maybe also on the qemu for mvme3100?
@Michael: Can you write me again where I can get the qemu mvme3100 from?
I'll try my luck and hope to make it to Melbourne.
Heinz
Das FHI verarbeitet, speichert und loescht Daten im Rahmen seiner
Geschaeftstaetigkeit gemaess der Datenschutz-Grundverordnung (DSGVO)
[General Data Protection Regulation (GDPR)] der Europaeischen Union.
Re: RTEMS5 with epics-base Michael Davidsaver
RTEMS5 with epics-base Heinz Junkes
Re: RTEMS5 with epics-base Heinz P. Junkes
Prev: Re: RTEMS5 with epics-base Heinz P. Junkes
Next: Re: RTEMS5 with epics-base Michael Davidsaver
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
ANJ, 07 Nov 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
