2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: hanging test in 3.15
To: "Johnson, Andrew N." <[email protected]>
Date: Fri, 9 Nov 2018 16:54:12 +0100
On 09.11.2018 06:07, Johnson, Andrew N. wrote:
Hi Dirk,
If you have (or can install) GNUmake 4.x there is a -O option that separates the output from different builds. This makes parallel jobs reasonable to use.
The ‘tapfiles’ target was added in Base-3.14.12.6 and is documented in the release notes for that release. That is generally the only place I document build system features because the AppDevGuide chapter is so old. After ‘make -O -j tapfiles’ you can do ‘make test-results’ to have the results printed, or ‘make junitfiles’ to feed junit results into a Jenkins plugin if you don’t like the tap plugin. Those are also documented in the release notes...
- Andrew
Found it. Thanks. I will try to use it in Jenkins with the TAP plugin.
Dirk
Re: hanging test in 3.15 Heinz P. Junkes
R7.0.2-rc1 tagged and published at APS Johnson, Andrew N. via Core-talk
Re: R7.0.2-rc1 tagged and published at APS Dirk Zimoch
Re: hanging test in 3.15 Johnson, Andrew N. via Core-talk
Re: hanging test in 3.15 Dirk Zimoch
Prev: Jenkins build is back to normal : EPICS-3.14 #155 Jenkins EPICS PSI
Next: Jenkins build is back to normal : EPICS-3.16 #151 Jenkins EPICS PSI
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  <20182019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: hanging test in 3.15 Johnson, Andrew N. via Core-talk
Next: Re: hanging test in 3.15 Heinz P. Junkes
ANJ, 10 Nov 2018 · Home · News · About · Talk · Base · Modules · Extensions ·
