2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Re: EPICS 3.15 and RTEMS 5
From: Benjamin Franksen via Core-talk <[email protected]>
To: EPICS Core-Talk <[email protected]>
Cc: Götz Pfeiffer <[email protected]>, EPICS Techtalk <[email protected]>
Date: Thu, 10 Jan 2019 13:26:16 +0100
Am 07.01.19 um 21:28 schrieb Johnson, Andrew N. via Tech-talk:
> The main complication with RTEMS 5.x which Heinz's not-yet-merged
> implementation handles is that the OS APIs changed when RTEMS added SMP
> support. We wanted to switch to the new Posix APIs for RTEMS 5.x, but
> the EPICS build rules make that hard to do without breaking support for
> RTEMS 4.x builds.
> There is a hint of our final solution in the presentation below, where
> on slide 14 you can see there are now 3 source subdirectories: RTEMS,
> RTEMS-kernel and RTEMS-posix. I won't explain why, just saying that this
> wasn't a trivial thing to do while still supporting older versions of
> RTEMS and not completely breaking applications that are using
> OS-specific source files in a src/os/RTEMS directory (e.g. iocStats).
> Heinz's code can be seen in a couple of git repo's on Launchpad, but it
> hasn't been updated to the latest Base releases. It should be possible
> to apply the necessary changes to the 3.15 branch instead of to 7.0, but
> there will need to be some work done to get anywhere from their current
> state (which IIRC pre-dated our recombining libCom into the EPICS core
> branch):
>   https://code.launchpad.net/~epics-core/epics-base/+git/rtems5
>   https://code.launchpad.net/~epics-core/epics-base/+git/rtems5libcom
> If others want to help with this I wouldn't expect Heinz to say no.
> Please use the core-talk mailing list for any technical questions and
> discussions.
We are also very much interested in getting RTEMS5 support into base,
preferably in a clean and backward compatible way. We have previously
offered to help with merging Heinz' changes and the offer still stands.
Cheers
Ben
Attachment: signature.asc
Description: OpenPGP digital signature
Re: EPICS 3.15 and RTEMS 5 Siddons, David via Core-talk
Prev: Re: 64-bit records Michael Davidsaver via Core-talk
Next: Re: EPICS 3.15 and RTEMS 5 Siddons, David via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Warning when building areaDetector with base 7.0.2 Mark Rivers via Core-talk
ANJ, 10 Jan 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
