2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Re: 64-bit records
From: Michael Davidsaver via Core-talk <[email protected]>
To: "Shen, Guobao" <[email protected]>
Cc: EPICS Core Talk <[email protected]>
Date: Wed, 9 Jan 2019 10:07:54 -0800
On 1/9/19 8:54 AM, Shen, Guobao wrote:
> Nice work.
> I accidentally found out that now the PV tool set requires strict type matching.
> I guess it is implemented intentionally. Right?
Well, yes.  For a some value of "intentional".  I tend to default
to strictness in parsing without necessarily understanding all of
the consequences.  This is certainly not the friendliest behavior.
> For example, with Timo's example, if I do a pvput with:
> $ pvput verylongOut 123456.78
> Old : verylongOut                   123456
> Error: parseToPOD: Extraneous characters
> New : verylongOut                   123456
> Thanks,
> Guobao
> On 1/9/19, 2:37 AM, "[email protected] on behalf of Timo Korhonen via Core-talk" <[email protected] on behalf of [email protected]> wrote:
>     As commented on the tracker, I re-built and tested, now it works. Thanks
>     Michael for the super fast fix!
>     @Ernest: Michael already replied concerning testing. You can also build an
>     IOC, pointing to the 7.0.2 base and the latest fix by Michael.
>     Nothing very special is needed; I attached the makefile and st.cmd that I
>     used, just for reference.
>     Just add records something like this:
>     record(int64in, "verylongIn")
>       field(DTYP,"Soft Channel")
>     record(int64out, "verylongOut")
>     (I added the DTYP, just to be sure. Would be the default anyway.)
>     Cheers,
>     Timo
>     On 08/01/19 17:00, "Michael Davidsaver" <[email protected]> wrote:
>     >On 1/8/19 3:08 AM, Timo Korhonen via Core-talk wrote:
>     >> Hi all,
>     >> I made a quick try to use the 64-bit record types (int64in/int64out)
>     >>with base 7.0.2.
>     >> Trying to pvget the record, I get the following message on the IOC
>     >>console:
>     >> epics> 2019-01-08T11:43:50.309 an exception caught while in
>     >>receiveThread at ../../src/remote/codec.cpp:1144: Unsupported DBR code
>     >https://github.com/search?q=%22Unsupported+DBR+code%22&type=Code
>     >points to QSRV.
>     >> And pvget times out. With caget, I can read the value but as expected,
>     >>I do not get the 64-bit integer (because ca does not support it,
>     >>obviously).
>     >> Any ideas? Maybe I am missing some configuration, but I could not
>     >>figure out from the release notes if I needed to do something extra.
>     >No, this is probably a regression on my part.  I thought I had added
>     >tests with the int64in/out record types, but apparently I have not (yet).
>     >> This is on Mac OSX El Capitan, 10.11.6. I can try other platforms later
>     >>but at the first sight this does not appear to be a platform-specific
>     >>issue.
>     >> Timo
64-bit records Timo Korhonen via Core-talk
Re: 64-bit records Michael Davidsaver via Core-talk
Re: 64-bit records Timo Korhonen via Core-talk
Re: 64-bit records Shen, Guobao via Core-talk
Prev: Re: 64-bit records Shen, Guobao via Core-talk
Next: Re: EPICS 3.15 and RTEMS 5 Benjamin Franksen via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Next: Re: 64-bit records Michael Davidsaver via Core-talk
ANJ, 10 Jan 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
