2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Re: 64-bit records
From: "Shen, Guobao via Core-talk" <[email protected]>
To: Timo Korhonen <[email protected]>, Michael Davidsaver <[email protected]>, "Williams Jr., Ernest L." <[email protected]>
Cc: EPICS Core Talk <[email protected]>
Date: Wed, 9 Jan 2019 16:54:25 +0000
Nice work.
I accidentally found out that now the PV tool set requires strict type matching.
I guess it is implemented intentionally. Right?
For example, with Timo's example, if I do a pvput with:
$ pvput verylongOut 123456.78
Old : verylongOut                   123456
Error: parseToPOD: Extraneous characters
New : verylongOut                   123456
Guobao
On 1/9/19, 2:37 AM, "[email protected] on behalf of Timo Korhonen via Core-talk" <[email protected] on behalf of [email protected]> wrote:
    As commented on the tracker, I re-built and tested, now it works. Thanks
    Michael for the super fast fix!
    @Ernest: Michael already replied concerning testing. You can also build an
    IOC, pointing to the 7.0.2 base and the latest fix by Michael.
    Nothing very special is needed; I attached the makefile and st.cmd that I
    used, just for reference.
    Just add records something like this:
    record(int64in, "verylongIn")
      field(DTYP,"Soft Channel")
    record(int64out, "verylongOut")
    (I added the DTYP, just to be sure. Would be the default anyway.)
    Cheers,
    Timo
    On 08/01/19 17:00, "Michael Davidsaver" <[email protected]> wrote:
    >On 1/8/19 3:08 AM, Timo Korhonen via Core-talk wrote:
    >> Hi all,
    >> I made a quick try to use the 64-bit record types (int64in/int64out)
    >>with base 7.0.2.
    >> Trying to pvget the record, I get the following message on the IOC
    >>console:
    >> epics> 2019-01-08T11:43:50.309 an exception caught while in
    >>receiveThread at ../../src/remote/codec.cpp:1144: Unsupported DBR code
    >https://github.com/search?q=%22Unsupported+DBR+code%22&type=Code
    >points to QSRV.
    >> And pvget times out. With caget, I can read the value but as expected,
    >>I do not get the 64-bit integer (because ca does not support it,
    >>obviously).
    >> Any ideas? Maybe I am missing some configuration, but I could not
    >>figure out from the release notes if I needed to do something extra.
    >No, this is probably a regression on my part.  I thought I had added
    >tests with the int64in/out record types, but apparently I have not (yet).
    >> This is on Mac OSX El Capitan, 10.11.6. I can try other platforms later
    >>but at the first sight this does not appear to be a platform-specific
    >>issue.
    >> Timo
Re: 64-bit records Michael Davidsaver via Core-talk
64-bit records Timo Korhonen via Core-talk
Re: 64-bit records Timo Korhonen via Core-talk
Prev: Re: 64-bit records Timo Korhonen via Core-talk
Next: Re: 64-bit records Michael Davidsaver via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
ANJ, 09 Jan 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
