2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Build failed in Jenkins: EPICS-3.14 #245
From: Jenkins EPICS PSI via Core-talk <[email protected]>
To: <[email protected]>, <[email protected]>
Date: Sat, 16 Mar 2019 19:21:08 +0100
See <http://gfa-sls2-test:8080/job/EPICS-3.14/245/display/redirect>
Started by timer
Building in workspace <http://gfa-sls2-test:8080/job/EPICS-3.14/ws/>
[WS-CLEANUP] Deleting project workspace...
[WS-CLEANUP] Deferred wipeout is used...
[WS-CLEANUP] Done
Cloning the remote Git repository
Cloning repository https://git.launchpad.net/epics-base
 > git init <http://gfa-sls2-test:8080/job/EPICS-3.14/ws/> # timeout=10
Fetching upstream changes from https://git.launchpad.net/epics-base
 > git --version # timeout=10
 > git fetch --tags --progress https://git.launchpad.net/epics-base +refs/heads/*:refs/remotes/origin/*
ERROR: Error cloning remote repo 'origin'
hudson.plugins.git.GitException: Command "git fetch --tags --progress https://git.launchpad.net/epics-base +refs/heads/*:refs/remotes/origin/*" returned status code 128:
stdout:
stderr: remote: Counting objects: 1           remote: Counting objects: 4           remote: Counting objects: 35           remote: Counting objects: 49           remote: Counting objects: 69           remote: Counting objects: 100           remote: Counting objects: 121           remote: Counting objects: 151           remote: Counting objects: 177           remote: Counting objects: 206           remote: Counting objects: 228           remote: Counting objects: 274           remote: Counting objects: 306           remote: Counting objects: 337           remote: Counting objects: 375           remote: Counting objects: 384           remote: Counting objects: 410           remote: Counting objects: 487           remote: Counting objects: 534           remote: Counting objects: 538           remote: Counting objects: 568           remote: Counting objects: 624           remote: Counting objects: 704           remote: Counting objects: 865           remote: Counting objects: 964           remote: Counting objects: 3559           remote: Counting objects: 5761           remote: Counting objects: 16491           remote: Counting objects: 17077           remote: Counting objects: 17267           remote: Counting objects: 17383           remote: Counting objects: 18003           remote: Counting objects: 18153           remote: Counting objects: 18572           remote: Counting objects: 18780           remote: Counting objects: 19112           remote: Counting objects: 19355           remote: Counting objects: 19463           remote: Counting objects: 19478           remote: Counting objects: 19671           remote: Counting objects: 19876           remote: Counting objects: 20078           remote: Counting objects: 20405           remote: Counting objects: 20440           remote: Counting objects: 20629           remote: Counting objects: 20807           remote: Counting objects: 21649           remote: Counting objects: 21775           remote: Counting objects: 21898           remote: Counting objects: 21937           remote: Counting objects: 22081           remote: Counting objects: 22223           remote: Counting objects: 22385           remote: Counting objects: 22484           remote: Counting objects: 22539           remote: Counting objects: 22564           remote: Counting objects: 22654           remote: Counting objects: 22805           remote: Counting objects: 22851           remote: Counting objects: 22937           remote: Counting objects: 23008           remote: Counting objects: 23129           remote: Counting objects: 23210           remote: Counting objects: 23291           remote: Counting objects: 23422           remote: Counting objects: 23599           remote: Counting objects: 23850           remote: Counting objects: 24602           remote: Counting objects: 24653           remote: Counting objects: 24662           remote: Counting objects: 24664           remote: Counting objects: 24683           remote: Counting objects: 24849           remote: Counting objects: 25416           remote: Counting objects: 25613           remote: Counting objects: 26836           remote: Counting objects: 28922           remote: Counting objects: 34204           remote: Counting objects: 39512           remote: Counting objects: 44404           remote: Counting objects: 49152           remote: Counting objects: 55023           remote: Counting objects: 61441           remote: Counting objects: 66195           remote: Counting objects: 71485           remote: Counting objects: 74426           remote: Counting objects: 75693           remote: Counting objects: 81660           remote: Counting objects: 87813           remote: Counting objects: 94310           remote: Counting objects: 98993           remote: Counting objects: 104995           remote: Counting objects: 110838           remote: Counting objects: 117976           remote: Counting objects: 119279, done.
fatal: The remote end hung up unexpectedly
fatal: protocol error: bad pack header
	at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.launchCommandIn(CliGitAPIImpl.java:2016)
	at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.launchCommandWithCredentials(CliGitAPIImpl.java:1735)
	at org.jenkinsci.plugins.gitclient.CliGitAPIImpl.access$300(CliGitAPIImpl.java:72)
	at org.jenkinsci.plugins.gitclient.CliGitAPIImpl$1.execute(CliGitAPIImpl.java:420)
	at org.jenkinsci.plugins.gitclient.CliGitAPIImpl$2.execute(CliGitAPIImpl.java:629)
	at hudson.plugins.git.GitSCM.retrieveChanges(GitSCM.java:1146)
	at hudson.plugins.git.GitSCM.checkout(GitSCM.java:1186)
	at hudson.scm.SCM.checkout(SCM.java:504)
	at hudson.model.AbstractProject.checkout(AbstractProject.java:1208)
	at hudson.model.AbstractBuild$AbstractBuildExecution.defaultCheckout(AbstractBuild.java:574)
	at jenkins.scm.SCMCheckoutStrategy.checkout(SCMCheckoutStrategy.java:86)
	at hudson.model.AbstractBuild$AbstractBuildExecution.run(AbstractBuild.java:499)
	at hudson.model.Run.execute(Run.java:1819)
	at hudson.model.FreeStyleBuild.run(FreeStyleBuild.java:43)
	at hudson.model.ResourceController.execute(ResourceController.java:97)
	at hudson.model.Executor.run(Executor.java:429)
[WARNINGS] Skipping publisher since build result is FAILURE
Jenkins build is back to normal : EPICS-3.14 #246 Jenkins EPICS PSI via Core-talk
Prev: Re: pvAccessCPP: destroyable.h Marty Kraimer via Core-talk
Next: Jenkins build is back to normal : EPICS-3.14 #246 Jenkins EPICS PSI via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Prev: Re: EPICS 7.0.2.1 release preparation Johnson, Andrew N. via Core-talk
ANJ, 08 May 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
