2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Subject: Re: Get sub field of Union
From: "Shen, Guobao via Core-talk" <[email protected]>
To: Michael Davidsaver <[email protected]>
Date: Thu, 21 Mar 2019 21:10:45 +0000
The union is what we are using for our fast DAQ data from FPGA.
Our engineers designed the structure that format, and it has similar structure with AD image.
We do not use a union containing a structure, which might complicate the system.
In this case, you mean what I got is what I should expect. Right?
On 3/21/19, 1:20 PM, "Michael Davidsaver" <[email protected]> wrote:
    On 3/21/19 8:43 AM, Shen, Guobao via Core-talk wrote:
    > Hi Core member,
    > Does anyone have experienced to read sub field of a Union structure?
    What you are showing looks like a discriminating/tagged union.
    This is quite different to having a union containing a structure,
    which is maybe what you expect?
    > For example, I have a record:
    > $ pvinfo Test:Data
    > structure
    >     uint ArrayId
    >     double[] Time
    >     union value
    >         float[] data1
    >         double[] data2
    > If I use
    > $ pvget -r value Test:Data
    > Test:Data
    > structure
    >     union value
    >         float[]  [-0.034794,-0.0417011, …]
    > But if I do it with:
    > $ pvget -r value.data1 Test:Data
    > I got an error on my client like
    > [Test: Data] failed to create channel get: Status [type=FATAL, message=std::bad_alloc]
    > Is that a right way to use it for union?
    > Thanks,
    > Guobao
Re: Get sub field of Union Johnson, Andrew N. via Core-talk
Re: Get sub field of Union Michael Davidsaver via Core-talk
Get sub field of Union Shen, Guobao via Core-talk
Prev: Re: Get sub field of Union Michael Davidsaver via Core-talk
Next: Re: Get sub field of Union Johnson, Andrew N. via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
ANJ, 21 Mar 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
