2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Subject: Re: Get sub field of Union
From: Michael Davidsaver via Core-talk <[email protected]>
To: "Shen, Guobao" <[email protected]>
Date: Thu, 21 Mar 2019 16:03:04 -0700
On 3/21/19 2:10 PM, Shen, Guobao wrote:
> The union is what we are using for our fast DAQ data from FPGA.
> Our engineers designed the structure that format, and it has similar structure with AD image.
> We do not use a union containing a structure, which might complicate the system.
> In this case, you mean what I got is what I should expect. Right?
Yes.  What you see is what I would expect.
This will work.
> $ pvget -r value Test:Data
This is not meaningful.
> $ pvget -r value.data1 Test:Data
I will grant you that 'Status [type=FATAL, message=std::bad_alloc]'
is not the error I would have expected to see from the pvRequest string parser.
> On 3/21/19, 1:20 PM, "Michael Davidsaver" <[email protected]> wrote:
>     On 3/21/19 8:43 AM, Shen, Guobao via Core-talk wrote:
>     > Hi Core member,
>     > Does anyone have experienced to read sub field of a Union structure?
>     What you are showing looks like a discriminating/tagged union.
>     This is quite different to having a union containing a structure,
>     which is maybe what you expect?
>     > For example, I have a record:
>     > $ pvinfo Test:Data
>     > structure
>     >     uint ArrayId
>     >     double[] Time
>     >     union value
>     >         float[] data1
>     >         double[] data2
>     > If I use
>     > Test:Data
>     > structure
>     >     union value
>     >         float[]  [-0.034794,-0.0417011, …]
>     > But if I do it with:
>     > I got an error on my client like
>     > [Test: Data] failed to create channel get: Status [type=FATAL, message=std::bad_alloc]
>     > Is that a right way to use it for union?
>     > Thanks,
>     > Guobao
Re: Get sub field of Union Benjamin Franksen via Core-talk
Get sub field of Union Shen, Guobao via Core-talk
Re: Get sub field of Union Michael Davidsaver via Core-talk
Re: Get sub field of Union Shen, Guobao via Core-talk
Prev: Re: Get sub field of Union Johnson, Andrew N. via Core-talk
Next: Re: Get sub field of Union Marty Kraimer via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Next: Re: Get sub field of Union Benjamin Franksen via Core-talk
ANJ, 27 Mar 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
