2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Subject: Re: PV Access Protocol Specification
From: "Kasemir, Kay via Core-talk" <[email protected]>
To: Bruno Martins <[email protected]>
Date: Wed, 10 Apr 2019 15:39:37 +0000
> Related:  https://epics.anl.gov/core-talk/2018/msg00284.php
Alright, so missing info about size encoding is a known issue.
Also related:
The element count encoding of the search request for the channel names,
  struct {
        int searchInstanceID;
        string channelName;
    } channels[];
always seems to use a 2-byte short count, not the usual size encoding.
I assume that's because all implementations currently start with
  short count: 0
and then keep updating the buffer in place:
  short count: 1
  int some_channel_id
  string some_channel_name
  short count: 2
  int some_channel_id
  int some_channel_id
With normal size encoding, once you have count >= 254 you'd have to shift all channel ids and names down to make room for a larger count.
-Kay
Re: PV Access Protocol Specification Michael Davidsaver via Core-talk
PV Access Protocol Specification Kasemir, Kay via Core-talk
Re: PV Access Protocol Specification Timo Korhonen via Core-talk
Re: PV Access Protocol Specification Kasemir, Kay via Core-talk
Re: PV Access Protocol Specification Bruno Martins via Core-talk
Prev: Re: PV Access Protocol Specification Michael Davidsaver via Core-talk
Next: Re: PV Access Protocol Specification Johnson, Andrew N. via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Prev: Re: PV Access Protocol Specification Bruno Martins via Core-talk
Next: Re: PV Access Protocol Specification Michael Davidsaver via Core-talk
ANJ, 10 Apr 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
