2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Re: PV Access Protocol Specification
From: Michael Davidsaver via Core-talk <[email protected]>
To: "Kasemir, Kay" <[email protected]>, Bruno Martins <[email protected]>
Date: Wed, 10 Apr 2019 09:28:47 -0700
On 4/10/19 8:39 AM, Kasemir, Kay via Core-talk wrote:
> From: Bruno Martins <[email protected]>
>> Related:  https://epics.anl.gov/core-talk/2018/msg00284.php
> Alright, so missing info about size encoding is a known issue.
> Also related:
> The element count encoding of the search request for the channel names,
>   struct {
>         int searchInstanceID;
>         string channelName;
>     } channels[];
> always seems to use a 2-byte short count, not the usual size encoding.
yup.
https://github.com/epics-base/pvAccessCPP/blob/78410499f0236f5830a0937567bbb794de7b2347/src/server/responseHandlers.cpp#L281
https://github.com/mdavidsaver/cashark/blob/7ea746615292e33ed44d6f3a54c6181996804a33/pva.lua#L379-L383
> I assume that's because all implementations currently start with
>   short count: 0
> and then keep updating the buffer in place:
Also yes.
https://github.com/epics-base/pvAccessCPP/blob/78410499f0236f5830a0937567bbb794de7b2347/src/remote/channelSearchManager.cpp#L256-L275
the "ick!!!" comment is mine.
https://github.com/epics-base/pvAccessCPP/blob/78410499f0236f5830a0937567bbb794de7b2347/src/remote/channelSearchManager.cpp#L57-L58
>   short count: 1
>   int some_channel_id
>   string some_channel_name
>   short count: 2
>   int some_channel_id
>   int some_channel_id
> With normal size encoding, once you have count >= 254 you'd have to shift all channel ids and names down to make room for a larger count.
> -Kay
PV Access Protocol Specification Kasemir, Kay via Core-talk
Re: PV Access Protocol Specification Timo Korhonen via Core-talk
Re: PV Access Protocol Specification Kasemir, Kay via Core-talk
Re: PV Access Protocol Specification Bruno Martins via Core-talk
Prev: Re: PV Access Protocol Specification Johnson, Andrew N. via Core-talk
Next: Re: PV Access Protocol Specification Michael Davidsaver via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Prev: Re: PV Access Protocol Specification Kasemir, Kay via Core-talk
Next: Re: PV Access Protocol Specification Timo Korhonen via Core-talk
ANJ, 10 Apr 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
