2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Sequencer segfaults when using put completion with no access to PV
From: Benjamin Franksen via Core-talk <[email protected]>
To: "Konrad, Martin" <[email protected]>, "[email protected]" <[email protected]>
Cc: EPICS Core-Talk <[email protected]>
Date: Thu, 11 Apr 2019 14:30:36 +0200
Am 10.04.19 um 15:59 schrieb Konrad, Martin:
> I'm experiencing a crash when using the sequencer with
> pvPut(foo, SYNC)
> while it has no access to PV "foo" due to Access Security constraints
> (see backtrace.txt).
> I can reproduce this with the latest development version of the
> sequencer. Replace all pvPuts in the demo example and insert
> asSetFilename("does-not-exist.acf")
> at the beginning of demo.stcmd to reproduce the problem.
I can reproduce this, using the steps you indicated. Thanks for the bug
report!
It looks to me as if the bug is in base, however, not the sequencer.
This is the backtrace I get from the core dump:
(gdb) bt
#0  0x00007f054d1ecc4f in dbProcessNotify (ppn=0x7f050c057d68) at
../../../src/ioc/db/dbNotify.c:351
#1  0x00007f054d200ed4 in dbPutNotifyBlocker::initiatePutNotify
(this=0x7f050c057d50, guard=..., notify=...,
dbch=dbch@entry=0x7f050c013298, type=type@entry=5, count=count@entry=1,
pValue=0x55e5bdff4f20) at ../../../src/ioc/db/dbPutNotifyBlocker.cpp:183
#2  0x00007f054d1feb41 in dbContext::initiatePutNotify
(this=0x7f050c000e30, guard=..., chan=..., dbch=0x7f050c013298,
type=type@entry=5, count=count@entry=1, pValue=<optimized out>,
notifyIn=..., pId=0x0) at ../../../src/ioc/db/dbContext.cpp:257
#3  0x00007f054d1ffdfd in dbChannelIO::write (this=0x7f050c013370,
guard=..., type=5, count=1, pValue=0x55e5bdff4f20, notify=..., pId=0x0)
at ../../../src/ioc/db/dbChannelIO.cpp:107
#4  0x00007f054c38b218 in ca_array_put_callback (type=5,
count=count@entry=1, pChan=0x7f050c000f10,
pValue=pValue@entry=0x55e5bdff4f20, pfunc=pfunc@entry=0x7f054b325010
<pvCaPutHandler>, usrarg=usrarg@entry=0x7f050c04fc90) at
../oldChannelNotify.cpp:432
#5  0x00007f054b32599b in pvVarPutCallback
(var=var@entry=0x55e5bdff5978, type=<optimized out>,
count=count@entry=1, value=value@entry=0x55e5bdff4f20,
arg=arg@entry=0x7f050c04fc90) at ../pv.c:122
#6  0x00007f054cd3e073 in seq_pvPutTmo (ss=0x55e5bdff5190, chId=0,
compType=SYNC, tmo=10) at ../seq_if.c:515
#7  0x00007f054cd3a8fd in ss_entry (arg=0x55e5bdff5190) at ../seq_task.c:361
#8  0x00007f054cd3ae11 in sequencer (arg=0x55e5bdff4d00) at
../seq_task.c:101
#9  0x00007f054cf8add8 in start_routine (arg=0x55e5bdff5f50) at
../../../src/libCom/osi/os/posix/osdThread.c:403
#10 0x00007f054c1256db in start_thread (arg=0x7f05491ec700) at
pthread_create.c:463
#11 0x00007f054ca6688f in clone () at
../sysdeps/unix/sysv/linux/x86_64/clone.S:95
Since this is a technical issue deep down in the EPICS core I have
cross-posted this to @core-talk.
Cheers
Ben
Attachment: signature.asc
Description: OpenPGP digital signature
Prev: Re: PV Access Protocol Specification Timo Korhonen via Core-talk
Next: Images Re: PV Access Protocol Specification Kasemir, Kay via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Prev: Build failed in Jenkins: epics-base-7.0-win64s-test #17 APS Jenkins via Core-talk
Next: Build failed in Jenkins: epics-base-7.0-win64-test #17 APS Jenkins via Core-talk
ANJ, 15 Apr 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
