Subject: |
[Bug 1824277] Re: Regression in calcout setting constant links at runtime |
Ralph Lange via Core-talk <[email protected]> |
To: |
[email protected] |
Date: |
Fri, 26 Apr 2019 04:03:43 -0000 |
For me, this behaviour (constant in INP link is the value taken the next
time the link is processed) is the best option. (I don't like the
"write-through" to the value field.)
I would support making this behaviour consistent over all INPx/x,
DOL/VAL (in closed_loop) etc. combinations.
You received this bug notification because you are a member of EPICS
Core Developers, which is subscribed to EPICS Base.
Matching subscriptions: epics-core-list-subscription
https://bugs.launchpad.net/bugs/1824277
Title:
Status in EPICS Base:
In Progress
Status in EPICS Base 7.0 series:
In Progress
Bug description:
With the 3.15 branch, writing a literal number to a calcout.INP[A-L]
field causes the corresponding [A-L] field to be set to that number.
This works because the calcout record marks the INP fields as
special(SPC_MOD) and the calcout::special() routine calls
recGblInitConstantLink() to initialize the corresponding [A-L] field
from the new link string. I suspect that a number of the synApps
record types (transform, scalc, acalc etc.) probably use this same
technique.
Keenan Lang reported that this doesn't currently work on the 7.0
branch; the value in the [A-L] field doesn't change, which I have
confirmed.
This use of special() to reinitialize constant links is unusual,
normally putting a literal into a link field after record
initialization has no effect, but someone who worked on the calcout
record discovered this way to get it to work.
I think I know what's going on and how to fix it (change
dbPutFieldLink() to call dbAddLink() before the second call to
dbPutSpecial()), but I need to check that this won't break other
cases.
To manage notifications about this bug go to:
https://bugs.launchpad.net/epics-base/+bug/1824277/+subscriptions
Re: ICALEPCS 2019 Contributions Hill, Bruce via Core-talk
Re: ICALEPCS 2019 Contributions Steven M. Hartman via Core-talk
<2019>
2025
2026
[Bug 1824277] Re: Regression in calcout setting constant links at runtime Andrew Johnson via Core-talk
[Bug 1824732] Re: iocsh crashes when dealing with NULL iocshArgPersistentString Andrew Johnson via Core-talk
<2019>
2025
2026
