2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: [Merge] ~anj/epics-base/+git/base-3.15:decimate-filter into epics-base:3.15
From: Andrew Johnson via Core-talk <[email protected]>
To: [email protected]
Date: Tue, 04 Jun 2019 17:42:22 -0000
Andrew Johnson has proposed merging ~anj/epics-base/+git/base-3.15:decimate-filter into epics-base:3.15.
Requested reviews:
  EPICS Core Developers (epics-core)
For more details, see:
https://code.launchpad.net/~anj/epics-base/+git/base-3.15/+merge/368347
Add the decimation channel filter that Hinko and Emanuele were looking for to the 3.15 branch.
This merge request contains the filter code, user documentation in the filters.dbd.pod file and Release Notes, and test code.
Your team EPICS Core Developers is requested to review the proposed merge of ~anj/epics-base/+git/base-3.15:decimate-filter into epics-base:3.15.
diff --git a/documentation/RELEASE_NOTES.html b/documentation/RELEASE_NOTES.html
index 8ed4e04..c7fbc02 100644
--- a/documentation/RELEASE_NOTES.html
+++ b/documentation/RELEASE_NOTES.html
@@ -16,6 +16,23 @@
 <!-- Insert new items immediately below here ... -->
+<h3>Added new decimation channel filter</h3>
+<p>A new server-side filter has been added to the IOC for reducing the number
+and frequency of monitor updates from a channel by a client-specified factor.
+The filter's behaviour is quite simplistic, it passes the first monitor event it
+sees to the client and then drops the next N-1 events before passing another
+event. For example to sample a 60Hz channel at 1Hz, a 10Hz channel every 6
+seconds, or a 1Hz channel once every minute:</p>
+<pre>    Hal$ camonitor 'test:channel.{"dec":{"n":60}}'
+    ...</pre>
+<p>More information is included in the
+<a href="filters.html">filters</a><!-- href for the EPICS website -->
+<a href="../html/filters.html">documentation</a><!-- href for install tree -->
+file.</p>
 <h3>Cleaning up with Multiple CA contexts in a Process</h3>
 <p>Bruno Martins reported a problem with the CA client library at shutdown in a
diff --git a/src/std/filters/Makefile b/src/std/filters/Makefile
index d453989..3a27361 100644
--- a/src/std/filters/Makefile
+++ b/src/std/filters/Makefile
@@ -15,6 +15,7 @@ dbRecStd_SRCS += ts.c
 dbRecStd_SRCS += dbnd.c
 dbRecStd_SRCS += arr.c
 dbRecStd_SRCS += sync.c
+dbRecStd_SRCS += decimate.c
 HTMLS += filters.html
diff --git a/src/std/filters/decimate.c b/src/std/filters/decimate.c
new file mode 100644
index 0000000..d34884e
--- /dev/null
+++ b/src/std/filters/decimate.c
@@ -0,0 +1,115 @@
+* Copyright (c) 2019 UChicago Argonne LLC, as Operator of Argonne
+*     National Laboratory.
+* Copyright (c) 2010 Brookhaven National Laboratory.
+* Copyright (c) 2010 Helmholtz-Zentrum Berlin
+*     fuer Materialien und Energie GmbH.
+* EPICS BASE is distributed subject to a Software License Agreement found
+* in file LICENSE that is included with this distribution.
+ *  Authors: Ralph Lange <[email protected]>,
+ *           Andrew Johnson <[email protected]>
+#include <stdio.h>
+#include "freeList.h"
+#include "db_field_log.h"
+#include "chfPlugin.h"
+#include "epicsExport.h"
+typedef struct myStruct {
+    epicsInt32 n, i;
+} myStruct;
+static void *myStructFreeList;
+static const
+chfPluginArgDef opts[] = {
+    chfInt32(myStruct, n, "n", 1, 0),
+    chfPluginArgEnd
+static void * allocPvt(void)
+    myStruct *my = (myStruct*) freeListCalloc(myStructFreeList);
+    return (void *) my;
+static void freePvt(void *pvt)
+    freeListFree(myStructFreeList, pvt);
+static int parse_ok(void *pvt)
+    myStruct *my = (myStruct*) pvt;
+    if (my->n < 1)
+        return -1;
+    return 0;
+static db_field_log* filter(void* pvt, dbChannel *chan, db_field_log *pfl) {
+    db_field_log *passfl = NULL;
+    epicsInt32 i = my->i;
+    if (pfl->ctx == dbfl_context_read)
+        return pfl;
+    if (i++ == 0)
+        passfl = pfl;
+    if (i >= my->n)
+        i = 0;
+    my->i = i;
+    return passfl;
+static void channelRegisterPre(dbChannel *chan, void *pvt,
+                               chPostEventFunc **cb_out, void **arg_out, db_field_log *probe)
+    *cb_out = filter;
+    *arg_out = pvt;
+static void channel_report(dbChannel *chan, void *pvt, int level, const unsigned short indent)
+    printf("%*sDecimate (dec): n=%d, i=%d\n", indent, "",
+           my->n, my->i);
+static chfPluginIf pif = {
+    allocPvt,
+    freePvt,
+    NULL, /* parse_error, */
+    parse_ok,
+    NULL, /* channel_open, */
+    channelRegisterPre,
+    NULL, /* channelRegisterPost, */
+    channel_report,
+    NULL /* channel_close */
+static void decInitialize(void)
+    static int firstTime = 1;
+    if (!firstTime) return;
+    firstTime = 0;
+    if (!myStructFreeList)
+        freeListInitPvt(&myStructFreeList, sizeof(myStruct), 64);
+    chfPluginRegister("dec", &pif, opts);
+epicsExportRegistrar(decInitialize);
diff --git a/src/std/filters/filters.dbd.pod b/src/std/filters/filters.dbd.pod
index f1a8484..d352d0e 100644
--- a/src/std/filters/filters.dbd.pod
+++ b/src/std/filters/filters.dbd.pod
@@ -14,6 +14,8 @@ The following filters are available in this release:
 =item * L<Synchronize|/"Synchronize Filter sync">
+=item * L<Decimation|/"Decimation Filter dec">
 =back
 =head2 Using Filters
@@ -245,3 +247,41 @@ periods only when "blue" is true by using
 =cut
+registrar(decInitialize)
+=head3 Decimation Filter C<"dec">
+This filter is used to reduce the number or rate of monitor updates from a
+channel by an integer factor C<n> that is provided as a filter argument,
+discarding the other updates. A true decimation following the original meaning
+of the word would be achieved by giving C<n> as 10, to only allow every tenth
+update through.
+=head4 Parameters
+=over
+=item Number C<"n">
+The decimation factor, a positive integer. Giving n=1 is equivalent to a no-op
+that allows all updates to be passed to the client.
+=back
+This filter is intentionally very simplistic. It passes on the first monitor
+event that it sees after the channel connects, then discards the next N-1 events
+before sending the next event. If several clients connect to a channel using the
+same filter settings they may see completely different data streams since each
+client gets its own instance of the filter whose event counter starts when that
+client connects.
+=head4 Example
+To sample a 60Hz channel at 1Hz, a 10Hz channel every 6 seconds or a 1Hz channel
+once every minute:
+ Hal$ camonitor 'test:channel' 'test:channel.{"dec":{"n":60}}'
+=cut
diff --git a/src/std/filters/test/Makefile b/src/std/filters/test/Makefile
index 6e6ad79..ad77c5d 100644
--- a/src/std/filters/test/Makefile
+++ b/src/std/filters/test/Makefile
@@ -56,6 +56,12 @@ syncTest_SRCS += filterTest_registerRecordDeviceDriver.cpp
 testHarness_SRCS += syncTest.c
 TESTS += syncTest
+TESTPROD_HOST += decTest
+decTest_SRCS += decTest.c
+decTest_SRCS += filterTest_registerRecordDeviceDriver.cpp
+testHarness_SRCS += decTest.c
+TESTS += decTest
 # epicsRunFilterTests runs all the test programs in a known working order.
 testHarness_SRCS += epicsRunFilterTests.c
diff --git a/src/std/filters/test/decTest.c b/src/std/filters/test/decTest.c
index 0000000..cc9317e
--- /dev/null
+++ b/src/std/filters/test/decTest.c
@@ -0,0 +1,273 @@
+#include <string.h>
+#include "dbStaticLib.h"
+#include "dbAccessDefs.h"
+#include "dbCommon.h"
+#include "dbChannel.h"
+#include "registry.h"
+#include "errlog.h"
+#include "dbmf.h"
+#include "epicsUnitTest.h"
+#include "dbUnitTest.h"
+#include "epicsTime.h"
+#include "testMain.h"
+#include "osiFileName.h"
+void filterTest_registerRecordDeviceDriver(struct dbBase *);
+static int fl_equal(const db_field_log *pfl1, const db_field_log *pfl2) {
+    return !(memcmp(pfl1, pfl2, sizeof(db_field_log)));
+static void fl_setup(dbChannel *chan, db_field_log *pfl, long val) {
+    struct dbCommon  *prec = dbChannelRecord(chan);
+    pfl->ctx  = dbfl_context_event;
+    pfl->type = dbfl_type_val;
+    pfl->stat = prec->stat;
+    pfl->sevr = prec->sevr;
+    pfl->time = prec->time;
+    pfl->field_type  = DBF_LONG;
+    pfl->no_elements = 1;
+     * use memcpy to avoid a bus error on
+     * union copy of char in the db at an odd
+     * address
+    memcpy(&pfl->u.v.field,
+           dbChannelField(chan),
+           dbChannelFieldSize(chan));
+    pfl->u.v.field.dbf_long = val;
+static void testHead (char* title) {
+    testDiag("--------------------------------------------------------");
+    testDiag("%s", title);
+static void mustDrop(dbChannel *pch, db_field_log *pfl, char* m) {
+    db_field_log *pfl2 = dbChannelRunPreChain(pch, pfl);
+    testOk(NULL == pfl2, "filter drops field_log (%s)", m);
+static void mustPass(dbChannel *pch, db_field_log *pfl, char* m) {
+    testOk(pfl == pfl2, "filter passes field_log (%s)", m);
+static void checkAndOpenChannel(dbChannel *pch, const chFilterPlugin *plug) {
+    ELLNODE *node;
+    chFilter *filter;
+    chPostEventFunc *cb_out = NULL;
+    void *arg_out = NULL;
+    db_field_log fl, fl1;
+    testDiag("Test filter structure and open channel");
+    testOk((ellCount(&pch->filters) == 1), "channel has one plugin");
+    fl_setup(pch, &fl, 1);
+    fl1 = fl;
+    node = ellFirst(&pch->filters);
+    filter = CONTAINER(node, chFilter, list_node);
+    plug->fif->channel_register_pre(filter, &cb_out, &arg_out, &fl1);
+    testOk(cb_out && arg_out,
+        "register_pre registers one filter with argument");
+    testOk(fl_equal(&fl1, &fl),
+        "register_pre does not change field_log data type");
+    testOk(!(dbChannelOpen(pch)), "dbChannel with plugin dec opened");
+    node = ellFirst(&pch->pre_chain);
+    filter = CONTAINER(node, chFilter, pre_node);
+    testOk((ellCount(&pch->pre_chain) == 1 && filter->pre_arg != NULL),
+        "dec has one filter with argument in pre chain");
+    testOk((ellCount(&pch->post_chain) == 0),
+        "sync has no filter in post chain");
+MAIN(decTest)
+    dbChannel *pch;
+    const chFilterPlugin *plug;
+    char myname[] = "dec";
+    db_field_log *pfl[10];
+    int i;
+    dbEventCtx evtctx;
+    testPlan(68);
+    testdbPrepare();
+    testdbReadDatabase("filterTest.dbd", NULL, NULL);
+    filterTest_registerRecordDeviceDriver(pdbbase);
+    testdbReadDatabase("xRecord.db", NULL, NULL);
+    eltc(0);
+    testIocInitOk();
+    eltc(1);
+    evtctx = db_init_events();
+    testOk(!!(plug = dbFindFilter(myname, strlen(myname))),
+        "plugin '%s' registered correctly", myname);
+    /* N < 1 */
+    testOk(!(pch = dbChannelCreate("x.VAL{\"dec\":{\"n\":-1}}")),
+           "dbChannel with dec (n=-1) failed");
+    testOk(!(pch = dbChannelCreate("x.VAL{\"dec\":{\"n\":0}}")),
+           "dbChannel with dec (n=0) failed");
+    /* Bad parms */
+    testOk(!(pch = dbChannelCreate("x.VAL{\"dec\":{}}")),
+           "dbChannel with dec (no parm) failed");
+    testOk(!(pch = dbChannelCreate("x.VAL{\"dec\":{\"x\":true}}")),
+           "dbChannel with dec (x=true) failed");
+    /* No Decimation (N=1) */
+    testHead("No Decimation (n=1)");
+    testOk(!!(pch = dbChannelCreate("x.VAL{\"dec\":{\"n\":1}}")),
+           "dbChannel with plugin dec (n=1) created");
+    checkAndOpenChannel(pch, plug);
+    for (i = 0; i < 5; i++) {
+        pfl[i] = db_create_read_log(pch);
+        fl_setup(pch, pfl[i], 10 + i);
+    testDiag("Test event stream");
+    mustPass(pch, pfl[0], "i=0");
+    mustPass(pch, pfl[1], "i=1");
+    mustPass(pch, pfl[2], "i=2");
+    mustPass(pch, pfl[3], "i=3");
+    mustPass(pch, pfl[4], "i=4");
+        db_delete_field_log(pfl[i]);
+    dbChannelDelete(pch);
+    /* Decimation (N=2) */
+    testHead("Decimation (n=2)");
+    testOk(!!(pch = dbChannelCreate("x.VAL{\"dec\":{\"n\":2}}")),
+           "dbChannel with plugin dec (n=2) created");
+    for (i = 0; i < 10; i++) {
+        fl_setup(pch, pfl[i], 20 + i);
+    mustDrop(pch, pfl[1], "i=1");
+    mustDrop(pch, pfl[3], "i=3");
+    mustDrop(pch, pfl[5], "i=5");
+    mustPass(pch, pfl[6], "i=6");
+    mustDrop(pch, pfl[7], "i=7");
+    mustPass(pch, pfl[8], "i=8");
+    mustDrop(pch, pfl[9], "i=9");
+    /* Decimation (N=3) */
+    testHead("Decimation (n=3)");
+    testOk(!!(pch = dbChannelCreate("x.VAL{\"dec\":{\"n\":3}}")),
+           "dbChannel with plugin dec (n=3) created");
+        fl_setup(pch, pfl[i], 30 + i);
+    mustDrop(pch, pfl[2], "i=2");
+    mustDrop(pch, pfl[4], "i=4");
+    mustDrop(pch, pfl[8], "i=8");
+    mustPass(pch, pfl[9], "i=9");
+    /* Decimation (N=4) */
+    testHead("Decimation (n=4)");
+    testOk(!!(pch = dbChannelCreate("x.VAL{\"dec\":{\"n\":4}}")),
+           "dbChannel with plugin dec (n=4) created");
+        fl_setup(pch, pfl[i], 40 + i);
+    mustDrop(pch, pfl[6], "i=6");
+    db_close_events(evtctx);
+    testIocShutdownOk();
+    testdbCleanup();
+    return testDone();
diff --git a/src/std/filters/test/epicsRunFilterTests.c b/src/std/filters/test/epicsRunFilterTests.c
index 2363643..5737d77 100644
--- a/src/std/filters/test/epicsRunFilterTests.c
+++ b/src/std/filters/test/epicsRunFilterTests.c
@@ -17,6 +17,7 @@ int tsTest(void);
 int dbndTest(void);
 int syncTest(void);
 int arrTest(void);
+int decTest(void);
 void epicsRunFilterTests(void)
@@ -26,6 +27,7 @@ void epicsRunFilterTests(void)
     runTest(dbndTest);
     runTest(syncTest);
     runTest(arrTest);
+    runTest(decTest);
     dbmfFreeChunks();
Re: [Merge] ~anj/epics-base/+git/base-3.15:decimate-filter into epics-base:3.15 mdavidsaver via Core-talk
Re: [Merge] ~anj/epics-base/+git/base-3.15:decimate-filter into epics-base:3.15 Andrew Johnson via Core-talk
[Merge] ~anj/epics-base/+git/base-3.15:decimate-filter into epics-base:3.15 noreply--- via Core-talk
Prev: Re: [Merge] ~epics-core/epics-base/+git/Com:iocsherr into epics-base:7.0 Keenan Lang via Core-talk
Next: Build failed in Jenkins: epics-base-3.15-win32-test #212 APS Jenkins via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Prev: RE: C++ string question Mark Rivers via Core-talk
Next: Re: [Merge] ~anj/epics-base/+git/base-3.15:decimate-filter into epics-base:3.15 mdavidsaver via Core-talk
ANJ, 21 Oct 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
