Subject: |
Re: [Merge] ~anj/epics-base/+git/base-3.15:decimate-filter into epics-base:3.15 |
mdavidsaver via Core-talk <[email protected]> |
To: |
Andrew Johnson <[email protected]> |
Date: |
Tue, 25 Jun 2019 01:42:06 -0000 |
Review: Needs Fixing
I think the dropped db_field_log are being leaked. See comments inline.
Diff comments:
> diff --git a/src/std/filters/decimate.c b/src/std/filters/decimate.c
> new file mode 100644
> index 0000000..d34884e
> --- /dev/null
> +++ b/src/std/filters/decimate.c
> @@ -0,0 +1,115 @@
> +* Copyright (c) 2019 UChicago Argonne LLC, as Operator of Argonne
> +* National Laboratory.
> +* Copyright (c) 2010 Brookhaven National Laboratory.
> +* Copyright (c) 2010 Helmholtz-Zentrum Berlin
> +* fuer Materialien und Energie GmbH.
> +* EPICS BASE is distributed subject to a Software License Agreement found
> +* in file LICENSE that is included with this distribution.
> + * Authors: Ralph Lange <[email protected]>,
> + * Andrew Johnson <[email protected]>
> +#include <stdio.h>
> +#include "freeList.h"
> +#include "db_field_log.h"
> +#include "chfPlugin.h"
> +#include "epicsExport.h"
> +typedef struct myStruct {
> + epicsInt32 n, i;
> +} myStruct;
> +static void *myStructFreeList;
> +static const
> +chfPluginArgDef opts[] = {
> + chfInt32(myStruct, n, "n", 1, 0),
> + chfPluginArgEnd
> +static void * allocPvt(void)
> + myStruct *my = (myStruct*) freeListCalloc(myStructFreeList);
> + return (void *) my;
> +static void freePvt(void *pvt)
> + freeListFree(myStructFreeList, pvt);
> +static int parse_ok(void *pvt)
> + myStruct *my = (myStruct*) pvt;
> + if (my->n < 1)
> + return -1;
> + return 0;
> +static db_field_log* filter(void* pvt, dbChannel *chan, db_field_log *pfl) {
> + db_field_log *passfl = NULL;
> + epicsInt32 i = my->i;
> + if (pfl->ctx == dbfl_context_read)
> + return pfl;
> + if (i++ == 0)
> + passfl = pfl;
> + if (i >= my->n)
> + i = 0;
> + my->i = i;
> + return passfl;
Should db_delete_field_log() be called if the entry is being dropped? (cf. dbnd.c)
> +static void channelRegisterPre(dbChannel *chan, void *pvt,
> + chPostEventFunc **cb_out, void **arg_out, db_field_log *probe)
> + *cb_out = filter;
> + *arg_out = pvt;
> +static void channel_report(dbChannel *chan, void *pvt, int level, const unsigned short indent)
> + printf("%*sDecimate (dec): n=%d, i=%d\n", indent, "",
> + my->n, my->i);
> +static chfPluginIf pif = {
> + allocPvt,
> + freePvt,
> + NULL, /* parse_error, */
> + parse_ok,
> + NULL, /* channel_open, */
> + channelRegisterPre,
> + NULL, /* channelRegisterPost, */
> + channel_report,
> + NULL /* channel_close */
> +static void decInitialize(void)
> + static int firstTime = 1;
> + if (!firstTime) return;
> + firstTime = 0;
> + if (!myStructFreeList)
> + freeListInitPvt(&myStructFreeList, sizeof(myStruct), 64);
> + chfPluginRegister("dec", &pif, opts);
> +epicsExportRegistrar(decInitialize);
> diff --git a/src/std/filters/test/decTest.c b/src/std/filters/test/decTest.c
> index 0000000..cc9317e
> --- /dev/null
> +++ b/src/std/filters/test/decTest.c
> @@ -0,0 +1,273 @@
> +#include <string.h>
> +#include "dbStaticLib.h"
> +#include "dbAccessDefs.h"
> +#include "dbCommon.h"
> +#include "dbChannel.h"
> +#include "registry.h"
> +#include "errlog.h"
> +#include "dbmf.h"
> +#include "epicsUnitTest.h"
> +#include "dbUnitTest.h"
> +#include "epicsTime.h"
> +#include "testMain.h"
> +#include "osiFileName.h"
> +void filterTest_registerRecordDeviceDriver(struct dbBase *);
The testing here seems a bit too nuts and bolts in not calling dbChannelOpen() and using dbChannelRunPreChain(). Which may be obscuring the fact that the plugin itself should be db_delete_field_log() the entries which it drops.
> +static int fl_equal(const db_field_log *pfl1, const db_field_log *pfl2) {
> + return !(memcmp(pfl1, pfl2, sizeof(db_field_log)));
> +static void fl_setup(dbChannel *chan, db_field_log *pfl, long val) {
> + struct dbCommon *prec = dbChannelRecord(chan);
> + pfl->ctx = dbfl_context_event;
> + pfl->type = dbfl_type_val;
> + pfl->stat = prec->stat;
> + pfl->sevr = prec->sevr;
> + pfl->time = prec->time;
> + pfl->field_type = DBF_LONG;
> + pfl->no_elements = 1;
> + * use memcpy to avoid a bus error on
> + * union copy of char in the db at an odd
> + * address
> + memcpy(&pfl->u.v.field,
> + dbChannelField(chan),
> + dbChannelFieldSize(chan));
> + pfl->u.v.field.dbf_long = val;
> +static void testHead (char* title) {
> + testDiag("--------------------------------------------------------");
> + testDiag("%s", title);
> +static void mustDrop(dbChannel *pch, db_field_log *pfl, char* m) {
> + db_field_log *pfl2 = dbChannelRunPreChain(pch, pfl);
> + testOk(NULL == pfl2, "filter drops field_log (%s)", m);
> +static void mustPass(dbChannel *pch, db_field_log *pfl, char* m) {
> + testOk(pfl == pfl2, "filter passes field_log (%s)", m);
> +static void checkAndOpenChannel(dbChannel *pch, const chFilterPlugin *plug) {
> + ELLNODE *node;
> + chFilter *filter;
> + chPostEventFunc *cb_out = NULL;
> + void *arg_out = NULL;
> + db_field_log fl, fl1;
> + testDiag("Test filter structure and open channel");
> + testOk((ellCount(&pch->filters) == 1), "channel has one plugin");
> + fl_setup(pch, &fl, 1);
> + fl1 = fl;
> + node = ellFirst(&pch->filters);
> + filter = CONTAINER(node, chFilter, list_node);
> + plug->fif->channel_register_pre(filter, &cb_out, &arg_out, &fl1);
> + testOk(cb_out && arg_out,
> + "register_pre registers one filter with argument");
> + testOk(fl_equal(&fl1, &fl),
> + "register_pre does not change field_log data type");
> + testOk(!(dbChannelOpen(pch)), "dbChannel with plugin dec opened");
> + node = ellFirst(&pch->pre_chain);
> + filter = CONTAINER(node, chFilter, pre_node);
> + testOk((ellCount(&pch->pre_chain) == 1 && filter->pre_arg != NULL),
> + "dec has one filter with argument in pre chain");
> + testOk((ellCount(&pch->post_chain) == 0),
> + "sync has no filter in post chain");
> +MAIN(decTest)
> + dbChannel *pch;
> + const chFilterPlugin *plug;
> + char myname[] = "dec";
> + db_field_log *pfl[10];
> + int i;
> + dbEventCtx evtctx;
> + testPlan(68);
> + testdbPrepare();
> + testdbReadDatabase("filterTest.dbd", NULL, NULL);
> + filterTest_registerRecordDeviceDriver(pdbbase);
> + testdbReadDatabase("xRecord.db", NULL, NULL);
> + eltc(0);
> + testIocInitOk();
> + eltc(1);
> + evtctx = db_init_events();
> + testOk(!!(plug = dbFindFilter(myname, strlen(myname))),
> + "plugin '%s' registered correctly", myname);
> + /* N < 1 */
> + testOk(!(pch = dbChannelCreate("x.VAL{\"dec\":{\"n\":-1}}")),
> + "dbChannel with dec (n=-1) failed");
> + testOk(!(pch = dbChannelCreate("x.VAL{\"dec\":{\"n\":0}}")),
> + "dbChannel with dec (n=0) failed");
> + /* Bad parms */
> + testOk(!(pch = dbChannelCreate("x.VAL{\"dec\":{}}")),
> + "dbChannel with dec (no parm) failed");
> + testOk(!(pch = dbChannelCreate("x.VAL{\"dec\":{\"x\":true}}")),
> + "dbChannel with dec (x=true) failed");
> + /* No Decimation (N=1) */
> + testHead("No Decimation (n=1)");
> + testOk(!!(pch = dbChannelCreate("x.VAL{\"dec\":{\"n\":1}}")),
> + "dbChannel with plugin dec (n=1) created");
> + checkAndOpenChannel(pch, plug);
> + for (i = 0; i < 5; i++) {
> + pfl[i] = db_create_read_log(pch);
> + fl_setup(pch, pfl[i], 10 + i);
> + testDiag("Test event stream");
> + mustPass(pch, pfl[0], "i=0");
> + mustPass(pch, pfl[1], "i=1");
> + mustPass(pch, pfl[2], "i=2");
> + mustPass(pch, pfl[3], "i=3");
> + mustPass(pch, pfl[4], "i=4");
> + db_delete_field_log(pfl[i]);
> + dbChannelDelete(pch);
> + /* Decimation (N=2) */
> + testHead("Decimation (n=2)");
> + testOk(!!(pch = dbChannelCreate("x.VAL{\"dec\":{\"n\":2}}")),
> + "dbChannel with plugin dec (n=2) created");
> + for (i = 0; i < 10; i++) {
> + fl_setup(pch, pfl[i], 20 + i);
> + mustDrop(pch, pfl[1], "i=1");
> + mustDrop(pch, pfl[3], "i=3");
> + mustDrop(pch, pfl[5], "i=5");
> + mustPass(pch, pfl[6], "i=6");
> + mustDrop(pch, pfl[7], "i=7");
> + mustPass(pch, pfl[8], "i=8");
> + mustDrop(pch, pfl[9], "i=9");
> + /* Decimation (N=3) */
> + testHead("Decimation (n=3)");
> + testOk(!!(pch = dbChannelCreate("x.VAL{\"dec\":{\"n\":3}}")),
> + "dbChannel with plugin dec (n=3) created");
> + fl_setup(pch, pfl[i], 30 + i);
> + mustDrop(pch, pfl[2], "i=2");
> + mustDrop(pch, pfl[4], "i=4");
> + mustDrop(pch, pfl[8], "i=8");
> + mustPass(pch, pfl[9], "i=9");
> + /* Decimation (N=4) */
> + testHead("Decimation (n=4)");
> + testOk(!!(pch = dbChannelCreate("x.VAL{\"dec\":{\"n\":4}}")),
> + "dbChannel with plugin dec (n=4) created");
> + fl_setup(pch, pfl[i], 40 + i);
> + mustDrop(pch, pfl[6], "i=6");
> + db_close_events(evtctx);
> + testIocShutdownOk();
> + testdbCleanup();
> + return testDone();
https://code.launchpad.net/~anj/epics-base/+git/base-3.15/+merge/368347
Your team EPICS Core Developers is subscribed to branch epics-base:3.15.
- [Merge] ~anj/epics-base/+git/base-3.15:decimate-filter into epics-base:3.15 Andrew Johnson via Core-talk
[Merge] ~info-martin-konrad/epics-base:fix-compiler-warnings into epics-base:3.15 noreply--- via Core-talk
Re: [Merge] ~info-martin-konrad/epics-base:clean-up-msi into epics-base:3.15 mdavidsaver via Core-talk
<2019>
2025
2026
Re: [Merge] ~anj/epics-base/+git/base-3.15:decimate-filter into epics-base:3.15 Andrew Johnson via Core-talk
<2019>
2025
2026
