2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Subject: Re: epicsThreadSleep and epicsThreadSleepQuantum
From: "Konrad, Martin via Core-talk" <[email protected]>
To: "Johnson, Andrew N." <[email protected]>, "[email protected]" <[email protected]>
Date: Fri, 14 Jun 2019 15:10:25 +0000
Hi Andrew,
> Then epicsThreadSleepQuantum() should return 0 in that case — the
> AppDevGuide says:
>> If this parameter is unknown or is unpredictable for a particular
>> OS then it is safe to return zero.
I understand that and it sounds reasonable. The problem is that I have
no idea how to detect if _SC_CLK_TCK makes sense or not. Without a way
to detect this, epicsThreadSleepQuantum() will return a wrong value on
modern Linux machines. I can think of two options:
1. Consider the value unknown on _all_ Linux machines. Modify
epicsThreadSleepQuantum() such that it _always_ returns 0 on Linux.
2. Leave epicsThreadSleepQuantum() as is and mark it deprecated to make
it obvious to developers that they are using something that might now
work as designed anymore.
-Martin
Martin Konrad
Facility for Rare Isotope Beams
Michigan State University
640 South Shaw Lane
East Lansing, MI 48824-1321, USA
Tel. 517-908-7253
Email: [email protected]
RE: epicsThreadSleep and epicsThreadSleepQuantum Mark Rivers via Core-talk
epicsThreadSleep and epicsThreadSleepQuantum Konrad, Martin via Core-talk
Re: epicsThreadSleep and epicsThreadSleepQuantum Konrad, Martin via Core-talk
Re: epicsThreadSleep and epicsThreadSleepQuantum Michael Davidsaver via Core-talk
Prev: Jenkins build is back to normal : 3.15-normativeTypes-win64s #128 APS Jenkins via Core-talk
Next: RE: epicsThreadSleep and epicsThreadSleepQuantum Mark Rivers via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Prev: Re: epicsThreadSleep and epicsThreadSleepQuantum Johnson, Andrew N. via Core-talk
ANJ, 14 Jun 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
