2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Subject: Re: IOC Threads blocking all signals
From: "Johnson, Andrew N. via Core-talk" <[email protected]>
Date: Wed, 19 Jun 2019 16:33:34 +0000
On 6/19/19 10:29 AM, Ralph Lange via Core-talk wrote:
Question:
It seems (looking at start_routine() in libCom/osi/osd/posix/osdThread.c) that all threads that the IOC starts are blocking all signals.
Is that correct, or am I missing something?
If that's correct, why is it done?
I concur with Eric's memory. I believe that before we did that a signal to the IOC process could get picked up by *any* thread, many of which were unprepared for the possibility. When a specific thread wants to respond to a signal it should be explicitly enabling it anyway.
We have a case where a separate process started from an EPICS IOC subordinate (driver) thread - via fork() and execv() calls - seems to be "immune" against all attempts to kill it
The child side of the fork() call needs to re-enable the default signal handling before it calls exec(), I think Eric suggested that too.
There are of course horror stories about mixing threads and fork():
  https://www.linuxprogrammingblog.com/threads-and-fork-think-twice-before-using-them
Any sockets opened using the epicsSocketCreate() or epicsSocketAccept() routines do have the FD_CLOEXEC flag set so they are protected, which should cover most network FDs (IOC, Asyn etc.).
- Andrew
Complexity comes for free, Simplicity you have to work for.
Re: IOC Threads blocking all signals Ralph Lange via Core-talk
Prev: Re: [Merge] ~epics-core/epics-base/+git/Com:thread-join into epics-base:7.0 mdavidsaver via Core-talk
Next: Re: [Merge] ~epics-core/epics-base/+git/Com:thread-join into epics-base:7.0 Andrew Johnson via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Prev: Re: IOC Threads blocking all signals William Norum via Core-talk
Next: Re: IOC Threads blocking all signals Ralph Lange via Core-talk
ANJ, 19 Jun 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
