2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Subject: Re: [Merge] ~anj/epics-base/+git/base-3.15:vxworks-tz-support into epics-base:3.15
From: Andrew Johnson via Core-talk <[email protected]>
Date: Tue, 25 Jun 2019 15:14:28 -0000
MAD: The RTEMS code will need adjusting when merging up to 7.0, try to add the tzset() as suggested.
https://code.launchpad.net/~anj/epics-base/+git/base-3.15/+merge/368570
Your team EPICS Core Developers is subscribed to branch epics-base:3.15.
[Merge] ~anj/epics-base/+git/base-3.15:vxworks-tz-support into epics-base:3.15 Andrew Johnson via Core-talk
Prev: Re: [Merge] ~anj/epics-base/+git/base-3.15:decimate-filter into epics-base:3.15 Andrew Johnson via Core-talk
Next: Re: [Merge] ~epics-core/epics-base/+git/asLib:as-hostname into epics-base:7.0 Andrew Johnson via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Prev: Re: [Merge] ~anj/epics-base/+git/base-3.15:vxworks-tz-support into epics-base:3.15 mdavidsaver via Core-talk
Next: Re: [Merge] ~anj/epics-base/+git/base-3.15:vxworks-tz-support into epics-base:3.15 Andrew Johnson via Core-talk
ANJ, 04 Oct 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
