2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Epics configure Makefile generation
From: Jeong Han Lee via Core-talk <[email protected]>
To: Heinz Junkes <[email protected]>
Cc: [email protected]
Date: Sat, 14 Sep 2019 01:41:41 +0200
Hi Heinz
I don't think I understand your question fully, but the following way I recently implemented a makefile rule into ESS EPICS building system to identify many variables. I've found it from the reference [1] such as
print-%:
	@echo $* = $($*)
	@echo $*\'s origin is $(origin $*)
  You can add them into your makefile rule, then it returns
  $ make print-EPICS_VERSION_STRING
EPICS_VERSION_STRING = EPICS Version 7.0.3
EPICS_VERSION_STRING's origin is file
  I hope this may match your question.
  Best,
  Han
[1] https://www.cmcrossroads.com/article/printing-value-makefile-variable
On 9/13/19 5:24 PM, Heinz Junkes via Core-talk wrote:
It was more of a general question how to simple debug the "make”.
These .rel entries no longer exist for my RTEMS5:
# Operating system flags
ifneq ($(RTEMS_SERIES),5)
OP_SYS_LDLIBS += -lrtemsCom -lc -lrtemscpu -lCom -lnfs -lm
endif
ifeq ($(RTEMS_SERIES),5)
OP_SYS_LDLIBS += -lrtemsCom -lnfs -ltftpfs
endif
OP_SYS_LDFLAGS_posix += -u POSIX_Init
OP_SYS_LDFLAGS_kernel += -u Init \
                  $(PROJECT_RELEASE)/lib/no-dpmem.rel \
                  $(PROJECT_RELEASE)/lib/no-mp.rel \
                  $(PROJECT_RELEASE)/lib/no-part.rel \
                  $(PROJECT_RELEASE)/lib/no-signal.rel \
                  $(PROJECT_RELEASE)/lib/no-rtmon.rel
OP_SYS_LDFLAGS += $(CPU_CFLAGS) $(OP_SYS_LDFLAGS_$(OS_API))
Viele Grüße
Heinz Junkes
Experience directly varies with equipment ruined.
On 13. Sep 2019, at 17:16, Michael Davidsaver <[email protected]> wrote:
On 9/13/19 3:15 AM, Heinz Junkes via Core-talk wrote:
I need to create a reasonable configure/os/CONFIG.Common.RTEMS-mvme2500
Is there a simple debug possibility to follow or test the generation of flags like OP_SYS_LDFLAGS etc.?
Are you asking about the .rel entries in configure/os/CONFIG.Common.RTEMS ?
OP_SYS_LDFLAGS += $(CPU_CFLAGS) -u Init \
I have occasionally wondered what when into selecting them, though unfortunately never
long enough to dig through the RTEMS documentation.
Re: Epics configure Makefile generation Johnson, Andrew N. via Core-talk
Epics configure Makefile generation Heinz Junkes via Core-talk
Re: Epics configure Makefile generation Michael Davidsaver via Core-talk
Re: Epics configure Makefile generation Heinz Junkes via Core-talk
Prev: Build failed in Jenkins: EPICS-3.14 #426 Jenkins EPICS PSI via Core-talk
Next: Re: Epics configure Makefile generation Johnson, Andrew N. via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Epics configure Makefile generation Michael Davidsaver via Core-talk
ANJ, 14 Sep 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
