2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Subject: Re: Epics configure Makefile generation
From: "Johnson, Andrew N. via Core-talk" <[email protected]>
To: Jeong Han Lee <[email protected]>
Date: Sat, 14 Sep 2019 11:58:23 +0000
We already have a rule like that built into Base, but it’s spelled PRINT.varname
- Andrew
Sent from my iPad
> On Sep 13, 2019, at 7:42 PM, Jeong Han Lee via Core-talk <[email protected]> wrote:
> Hi Heinz
>  I don't think I understand your question fully, but the following way I recently implemented a makefile rule into ESS EPICS building system to identify many variables. I've found it from the reference [1] such as
> print-%:
>    @echo $* = $($*)
>    @echo $*\'s origin is $(origin $*)
>  You can add them into your makefile rule, then it returns
>  $ make print-EPICS_VERSION_STRING
> EPICS_VERSION_STRING = EPICS Version 7.0.3
> EPICS_VERSION_STRING's origin is file
>  I hope this may match your question.
>  Best,
>  Han
> [1] https://www.cmcrossroads.com/article/printing-value-makefile-variable
>> On 9/13/19 5:24 PM, Heinz Junkes via Core-talk wrote:
>> It was more of a general question how to simple debug the "make”.
>> These .rel entries no longer exist for my RTEMS5:
>> # Operating system flags
>> ifneq ($(RTEMS_SERIES),5)
>> OP_SYS_LDLIBS += -lrtemsCom -lc -lrtemscpu -lCom -lnfs -lm
>> endif
>> ifeq ($(RTEMS_SERIES),5)
>> OP_SYS_LDLIBS += -lrtemsCom -lnfs -ltftpfs
>> endif
>> OP_SYS_LDFLAGS_posix += -u POSIX_Init
>> OP_SYS_LDFLAGS_kernel += -u Init \
>>                  $(PROJECT_RELEASE)/lib/no-dpmem.rel \
>>                  $(PROJECT_RELEASE)/lib/no-mp.rel \
>>                  $(PROJECT_RELEASE)/lib/no-part.rel \
>>                  $(PROJECT_RELEASE)/lib/no-signal.rel \
>>                  $(PROJECT_RELEASE)/lib/no-rtmon.rel
>> OP_SYS_LDFLAGS += $(CPU_CFLAGS) $(OP_SYS_LDFLAGS_$(OS_API))
>> Viele Grüße
>> Heinz Junkes
>> Experience directly varies with equipment ruined.
>>> On 13. Sep 2019, at 17:16, Michael Davidsaver <[email protected]> wrote:
>>> On 9/13/19 3:15 AM, Heinz Junkes via Core-talk wrote:
>>>> I need to create a reasonable configure/os/CONFIG.Common.RTEMS-mvme2500
>>>> Is there a simple debug possibility to follow or test the generation of flags like OP_SYS_LDFLAGS etc.?
>>> Are you asking about the .rel entries in configure/os/CONFIG.Common.RTEMS ?
>>>> OP_SYS_LDFLAGS += $(CPU_CFLAGS) -u Init \
>>> I have occasionally wondered what when into selecting them, though unfortunately never
>>> long enough to dig through the RTEMS documentation.
Re: Epics configure Makefile generation Heinz Junkes via Core-talk
Re: Epics configure Makefile generation Michael Davidsaver via Core-talk
Re: Epics configure Makefile generation Jeong Han Lee via Core-talk
Prev: Re: Epics configure Makefile generation Jeong Han Lee via Core-talk
Next: Build failed in Jenkins: EPICS-3.14 #427 Jenkins EPICS PSI via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <20192020  2021  2022  2023  2024  2025  2026
Next: Re: Epics configure Makefile generation Heinz Junkes via Core-talk
ANJ, 16 Sep 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
