2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: [Merge] ~freddie-akeroyd/epics-base:nan_inf_tests into epics-base:7.0
From: Freddie Akeroyd via Core-talk <[email protected]>
To: [email protected]
Date: Mon, 30 Sep 2019 20:37:22 -0000
Freddie Akeroyd has proposed merging ~freddie-akeroyd/epics-base:nan_inf_tests into epics-base:7.0.
Requested reviews:
  EPICS Core Developers (epics-core)
For more details, see:
https://code.launchpad.net/~freddie-akeroyd/epics-base/+git/epics-base/+merge/373425
Change tests to be more "a + -b" like than "a + -a" to avoid compiler optimisation issues
Your team EPICS Core Developers is requested to review the proposed merge of ~freddie-akeroyd/epics-base:nan_inf_tests into epics-base:7.0.
diff --git a/modules/libcom/test/epicsCalcTest.cpp b/modules/libcom/test/epicsCalcTest.cpp
index 2492c95..9edc7c6 100644
--- a/modules/libcom/test/epicsCalcTest.cpp
+++ b/modules/libcom/test/epicsCalcTest.cpp
@@ -294,6 +294,13 @@ static inline double MIN(double a, double b, double c, double d, double e,
 MAIN(epicsCalcTest)
     int repeat;
+     * we need to create these to avoid issues with "NaN + -NaN" etc
+     * and compiler optimisation. In the real world we would see a + -b
+     * rather than a + -a
+     * calc expressions are case insensive, so we can use "NaN + -NAN" in C
+    float inf = Inf, nan = NaN;
     const double a=1.0, b=2.0, c=3.0, d=4.0, e=5.0, f=6.0,
 		 g=7.0, h=8.0, i=9.0, j=10.0, k=11.0, l=12.0;
@@ -612,19 +619,11 @@ MAIN(epicsCalcTest)
     testExpr(0.0 + NaN);
     testExpr(Inf + 0.0);
     testExpr(Inf + Inf);
-#if defined(_WIN64) && defined(_MSC_VER)
-    testCalc("Inf + -Inf", NaN);
-#else
-    testExpr(Inf + -Inf);
-#endif
+    testExpr(Inf + -inf);
     testExpr(Inf + NaN);
     testExpr(-Inf + 0.0);
-    testCalc("-Inf + Inf", NaN);
-#else
-    testExpr(-Inf + Inf);
-#endif
-    testExpr(-Inf + -Inf);
+    testExpr(-Inf + inf);
+    testExpr(-Inf + -inf);
     testExpr(-Inf + NaN);
     testExpr(NaN + 0.0);
     testExpr(NaN + Inf);
@@ -638,11 +637,11 @@ MAIN(epicsCalcTest)
     testExpr(0.0 - NaN);
     testExpr(Inf - 0.0);
     testExpr(Inf - Inf);
-    testExpr(Inf - -Inf);
+    testExpr(Inf - -inf);
     testExpr(Inf - NaN);
     testExpr(-Inf - 0.0);
-    testExpr(-Inf - Inf);
-    testExpr(-Inf - -Inf);
+    testExpr(-Inf - inf);
+    testExpr(-Inf - -inf);
     testExpr(-Inf - NaN);
     testExpr(NaN - 0.0);
     testExpr(NaN - Inf);
diff --git a/modules/libcom/test/epicsMathTest.c b/modules/libcom/test/epicsMathTest.c
index 8ea763c..b3e67cf 100644
--- a/modules/libcom/test/epicsMathTest.c
+++ b/modules/libcom/test/epicsMathTest.c
@@ -20,6 +20,13 @@ MAIN(epicsMathTest)
     double huge = 1e300;
     double tiny = 1e-300;
     double c;
+     * we need to create these to avoid issues with "NaN + -NaN" etc and
+     * compiler optimisation. In the real world we would
+     * see a + -b rather than a + -a
+    float epicsINF_ = epicsINF;
+    float epicsNAN_ = epicsNAN;
     testPlan(35);
@@ -28,29 +35,17 @@ MAIN(epicsMathTest)
     testOk1(!isnan(epicsINF));
     testOk1(isinf(epicsINF));
-    testOk1(epicsINF == epicsINF);
+    testOk1(epicsINF == epicsINF_);
     testOk1(epicsINF > 0.0);
-    testOk1(epicsINF - epicsINF != 0.0);
+    testOk1(epicsINF - epicsINF_ != 0.0);
-    testTodoBegin("Known failure on windows-x64");
-#endif
-    testOk1(epicsINF + -epicsINF != 0.0);
-    testOk1(-epicsINF + epicsINF != 0.0);
-    testTodoEnd();
-#endif
+    testOk1(epicsINF + -epicsINF_ != 0.0);
+    testOk1(-epicsINF + epicsINF_ != 0.0);
     testOk1(isnan(epicsINF - epicsINF));
-#endif
-    testOk1(isnan(epicsINF + -epicsINF));
-    testOk1(isnan(-epicsINF + epicsINF));
-    testTodoEnd();
-#endif
+    testOk1(isnan(epicsINF + -epicsINF_));
+    testOk1(isnan(-epicsINF + epicsINF_));
     testOk1(isnan(epicsNAN));
     testOk1(!isinf(epicsNAN));
@@ -62,14 +57,8 @@ MAIN(epicsMathTest)
     testOk1(!(epicsNAN > epicsNAN));
     testOk1(isnan(epicsNAN - epicsNAN));
-#endif
-    testOk1(isnan(epicsNAN + -epicsNAN));
-    testOk1(isnan(-epicsNAN + epicsNAN));
-    testTodoEnd();
-#endif
+    testOk1(isnan(epicsNAN + -epicsNAN_));
+    testOk1(isnan(-epicsNAN + epicsNAN_));
     c = huge / tiny;
     testOk(!isnan(c), "!isnan(1e300 / 1e-300)");
Re: [Merge] ~freddie-akeroyd/epics-base:nan_inf_tests into epics-base:7.0 Andrew Johnson via Core-talk
Prev: Build failed: epics-base base-7.0-325 AppVeyor via Core-talk
Next: [Bug 1845854] Re: EPICS Math tests failing on Windows with MSVC Freddie Akeroyd via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Next: Re: [Merge] ~freddie-akeroyd/epics-base:nan_inf_tests into epics-base:7.0 Andrew Johnson via Core-talk
ANJ, 04 Oct 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
