Subject: |
Re: [Merge] ~freddie-akeroyd/epics-base:nan_inf_tests into epics-base:7.0 |
Andrew Johnson via Core-talk <[email protected]> |
To: |
[email protected] |
Date: |
Fri, 04 Oct 2019 15:19:14 -0000 |
Review: Needs Fixing
Group 10/4:
Suggest epicsCalcTest() should compare the string expression against the known expected result (for inf/nan calculations) so don't use Freddie's change as currently written to this file.
The epicsMathTest() changes are tricking the optimizer, which is a brittle thing. Idea is to concentrate these kinds of tests in this file, to document the known issues. As a result removing the compiler checks and calls to testToDo() from here is less helpful, we'd still like to see those until we stop building on compilers that fail. Having ToDo tests pass isn't a problem.
AI on MAD to merge and fix this.
https://code.launchpad.net/~freddie-akeroyd/epics-base/+git/epics-base/+merge/373425
Your team EPICS Core Developers is subscribed to branch epics-base:7.0.
- [Merge] ~freddie-akeroyd/epics-base:nan_inf_tests into epics-base:7.0 Freddie Akeroyd via Core-talk
Re: [Merge] ~freddie-akeroyd/epics-base:appveyor_debug_builds into epics-base:7.0 Andrew Johnson via Core-talk
Re: [Merge] ~epics-core/epics-base/+git/Com:errlog2syslog into epics-base:7.0 Andrew Johnson via Core-talk
<2019>
2025
2026
Build failed: epics-base base-7.0-328 AppVeyor via Core-talk
<2019>
2025
2026
