2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Proposed Changes in EPICS Base, PCAS and ca-gateway: Ignore IPs by environment / check IPs in access security
From: Ralph Lange via Core-talk <[email protected]>
To: EPICS Core Talk <[email protected]>
Date: Mon, 9 Dec 2019 16:33:30 +0100
I am with Lewis on this one.
For the user who specifies the list of name resolution requests to ignore, numeric or name or name:port or subnet are just different ways to specify the same thing. Having to remember that subnet specification needs to be set in a different variable seems unnecessary complex and exposes implementation detail in the API.
Cheers,
~Ralph
Proposed Changes in EPICS Base, PCAS and ca-gateway: Ignore IPs by environment / check IPs in access security Goetz Pfeiffer via Core-talk
Re: Proposed Changes in EPICS Base, PCAS and ca-gateway: Ignore IPs by environment / check IPs in access security J. Lewis Muir via Core-talk
Re: Proposed Changes in EPICS Base, PCAS and ca-gateway: Ignore IPs by environment / check IPs in access security Goetz Pfeiffer via Core-talk
Prev: Re: Proposed Changes in EPICS Base, PCAS and ca-gateway: Ignore IPs by environment / check IPs in access security Goetz Pfeiffer via Core-talk
Next: Build failed in Jenkins: epics-base-3.15-vx55 #414 APS Jenkins via Core-talk
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Next: Build failed: epics-base base-fix/c99math-287 AppVeyor via Core-talk
ANJ, 11 Dec 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
