I'm not sure whether all the motor guys read core-talk, just saying... On 2/5/20 9:02 AM, Torsten Bögershausen
via Core-talk wrote:
While debugging this and that, I find more and more thatThis seems reasonable as long as the API added is generic and the motor app doesn't become dependent on Asyn to compile, since I believe there are still motor drivers that don't need Asyn. Your code seems to be fine with that, but I haven't tested it. Other drivers should be free to implement their own logging interface method (which is what I think this API really is) to provide similar functionality if they wish. I have done a prototype here:Specific comments on your prototype: I thought the flag name ASYN_TRACE_INFO was discussed and rejected
in Asyn#63 back in December 2017. If
I'm right introducing it through a change to the motor app doesn't
seem right to me.The method name devVprintSource() in struct motor_dset emphasizes more how it's
implemented using Asyn, not what it's used for. I would recommend
thinking about names more like log_vprintf(). I admit the name is mostly used inside
a wrapper function inside motorRecord.cc but the name is visible
to anyone writing a new motor driver.Your change in motorDevSup.c appears to be only tangentially related to this topic, should it be extracted and applied separately? The non-Asyn implementation of debugPrint() will no longer display the
filename and line number of the message source, which used to be
explicitly listed in the Debug() format string arguments.
I'm not saying they necessarily need to appear, but I'm
pointing out the change for those who work more closely with the
motor record so they recognize and can comment on it.Requiring a __LINE__ argument to debugPrint() without __FILE__
looks a bit strange, I might consider using a macro to hide both
arguments from all those calls.HTH, - Andrew -- Complexity comes for free, Simplicity you have to work for.
| ANJ, 06 Feb 2020 |
Home
News
About
Talk
Base
Modules
Extensions
