Thanks Andrew and Michael,
Yes the ASYN_INFO was replaced by _STATE here:
<https://github.com/epics-modules/asyn/pull/67/commits/ffb84abc46679a6e1d0479674f0dd3e2e662a4cc>
And then the thing got stuck somewhat.
The discussion about .TPRO, .DDBG has not fully settled yet,
so for the moment I will continue to use the ".SPAM" field,
until a better solution is found.
I will address the other comments, thanks Andrew.
BR
/Torsten
PS: Sorry for the spam yesterday, mailman did the trick.
On 05/02/20 18:54, Andrew Johnson via Core-talk wrote:
Hi Torsten,
I'm not sure whether all the motor guys read core-talk, just saying...
On 2/5/20 9:02 AM, Torsten Bögershausen via Core-talk wrote:
While debugging this and that, I find more and more that
asynPrint() is a very useful feature.
Timestamps can be printed, file/line and/or the thread, all
is configurable in runtime.
Now to my question:
Is it a good idea to use it during record processing ?
Since the motorRecord does not have access to asyn directly,
all prints are fiddled through device support, which has
asyn.
In other words, this nice print works only for asynMotors
(But that restriction is OK).
This seems reasonable as long as the API added is generic and the motor
app doesn't become dependent on Asyn to compile, since I believe there
are still motor drivers that don't need Asyn. Your code seems to be fine
with that, but I haven't tested it. Other drivers should be free to
implement their own logging interface method (which is what I think this
API really is) to provide similar functionality if they wish.
I have done a prototype here:
<https://github.com/tboegi/motor/commit/9aebabdf551a24bd138d483808130af57888a9e0>
Specific comments on your prototype:
I thought the flag name|ASYN_TRACE_INFO|was discussed and rejected
inAsyn#63 <https://github.com/epics-modules/asyn/pull/63>back in
December 2017. If I'm right introducing it through a change to the motor
app doesn't seem right to me.
The method name|devVprintSource()|in|struct motor_dset|emphasizes more
how it's implemented using Asyn, not what it's used for. I would
recommend thinking about names more like|log_vprintf()|. I admit the
name is mostly used inside a wrapper function inside motorRecord.cc but
the name is visible to anyone writing a new motor driver.
Your change in motorDevSup.c appears to be only tangentially related to
this topic, should it be extracted and applied separately?
The non-Asyn implementation of|debugPrint()|will no longer display the
filename and line number of the message source, which used to be
explicitly listed in the|Debug()|format string arguments. I'm not saying
they necessarily /need/ to appear, but I'm pointing out the change for
those who work more closely with the motor record so they recognize and
can comment on it.
Requiring a |__LINE__| argument to |debugPrint()| without |__FILE__|
looks a bit strange, I might consider using a macro to hide both
arguments from all those calls.
HTH,
- Andrew
Complexity comes for free, Simplicity you have to work for.
- Using asynPrint() from motorRecord ? Torsten Bögershausen via Core-talk
- Re: Using asynPrint() from motorRecord ? Andrew Johnson via Core-talk
My Jenkins builds fail checking out. Why? Zimoch Dirk (PSI) via Core-talk
Re: My Jenkins builds fail checking out. Why? Torsten Bögershausen via Core-talk
<2020>
2025
2026
Build failed: epics-base base-integration-392 AppVeyor via Core-talk
<2020>
2025
2026
