On 06/02/20 08:56, Zimoch Dirk (PSI) via Core-talk wrote:
Hi everyone,
For 12 days now my Jenkins build fails for 3.15 checking out the sources:
19:02:10 Fetching upstream changes from https://git.launchpad.net/epics-base
19:02:10 > git fetch --tags --progress https://git.launchpad.net/epics-base +refs/heads/*:refs/remotes/origin/*
19:02:10 > git rev-parse origin/3.15^{commit} # timeout=10
19:02:10 > git rev-parse 3.15^{commit} # timeout=10
19:02:10 ERROR: Couldn't find any revision to build. Verify the repository and branch configuration for this job.
Builds for 3.14 and 7.0 succeed. 3.16 fails as well.
Can somebody give me a hint what has changed and
Nee, sorry.
what I may have to change in my Jenkins configuration?
I can try (to be helpful)
Your are running a fetch here.
Did you do a `git clone` before ?
And what is the status of the exit code ?
What does this give:
GIT_TRACE=true git fetch -v --tags --progress
; echo $?
# (probably this is not the problem ?)
And what are you using git rev-parse for ?
Your script is probably doing more things ?
Would it work to just checkout the remote branch ?
git checkout origin/3.15
I have:
Repository URL https://git.launchpad.net/epics-base
Branch Specifier 3.15
For the other versions I have Branch Specifier 3.14, 3.16, and 7.0.
Dirk
- My Jenkins builds fail checking out. Why? Zimoch Dirk (PSI) via Core-talk
Re: Using asynPrint() from motorRecord ? Torsten Bögershausen via Core-talk
Weird CAS hangup on IOC Ralph Lange via Core-talk
<2020>
2025
2026
Re: My Jenkins builds fail checking out. Why? Andrew Johnson via Core-talk
<2020>
2025
2026
